Results 1 to 9 of 9
Thread: Dsp5 not switching tunes
    Jul 2013
    Question Dsp5 not switching tunes
    my dsp5 is not switching tunes i checked can rechecked to make sure that the wires where in the right holes. I have taken a meter to them and got resistance and the resistance would chang when swithing the switch. On my lap top i have tryed to log data from the dsp voltage and it wont log anything saying that one that one pid has been selected and i checked to see if anything else was selected and nothing was and it also said to change the scanning speed. Only one of the tunes was able to be loaded to the truck.. Anyone got any ideas why the other tunes are not loading or what could be wrong
    Sep 2011
    Default Dsp5 not switching tunes
    Did you do a full flash, or a cali flash?
    Jul 2013
    Full flash is what i did
    Lifetime Member tokymon's Avatar
    Apr 2008
    can you data log either dsp5 voltage ( lb7-lly or lbz) and dsp5 tune#
    also check in you tune where the volages are set for each tune. i got caught with this they were all set at 0 voltage
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
    Jul 2013
    when i try to log data it says more than one pid has been selected when i have only clicked on one and then tryed to change the settings that it says to have on the pop up error and retry it and it just says the same thing
    Apr 2008
    post a screen shot
    stock sucks
    Nov 2005
    Where did you get your switch? What kind of vehicle are you attempting to flash?
    Cindy
    Jul 2013
    I got the switch from diesel addiction and it's for a 2005 duramax lly
    Nov 2005
    Time to post a screen shot.
    Cindy
  1. Dsp5 not switching
    By Landon_Buck in forum General
    Last Post: July 30th, 2013, 03:36 AM
  2. Switching dsp5 tunes in V2?
    By pavetim in forum General (Diesel)
    Last Post: September 9th, 2011, 06:19 AM
  3. DSP5 not switching?
    By JustinD in forum Duramax LB7
    Last Post: November 20th, 2010, 06:14 PM
  4. Switching DSP5 tunes with V2 module
    By kdawg62 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 4th, 2010, 02:18 PM
