Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: LML full tuning, it's here!
    Thumbs up LML full tuning, it's here!
    Hi All,
    As you may have heard through the grapevine (or even watched) on the internet, EFILive has indeed been working hard on the LML ECM to finally be able to offer you all a full tuning package just like the previous generation Duramax's. This is what everyone has been waiting for, a familir tuning / scanning package for the LML.
    So before the internet rumours start, here is a quick run down on what is coming and at the end an FAQ of sorts on how this will work, because the process is not quite the same as before.
    Those familiar with LMM tuning will feel right at home with the LML. It's not radically different to the LMM, the overall concepts are similar, the difference is you now have far greater controls due to the fact there is so many tables! What may have been 3 or 4 tables on the LMM for a function, the LML will have 12 of the same thing, the engineers at Bosch really went to town on this ECM.
    Here's some tables to look over.
    Pedal Response:
    Desired Boost:
    Timing:
    Rail Pressure:
    As of right now we have all known OS's mapped up to and including 2014 models. We are currently putting in the map descriptions, and finalising the folder layouts for the maps.
    Some other great news, the scantool got a major overhaul too with over 120 new PID's added, specifically for the LML and also the new Cruze Diesel E47 ECM. These new PID's give you vital feedback on everything in the emissions systems, great for making sure your tuning isn't going to block the DPF!
    With LML ECM support also brings back to the table the A50 TCM, support for this will follow soon after the ECM is 100% ready for public release.
    Keep an eye open for this update to go in to public release soon.
    Here's the FAQ.....
    Q - How do I get my stock tune?
    A - We are working on a solution to this. It is not possible to read the LML ECM via the OBDII port, GM/Bosch have blocked the reading of the calibrations, no ifs, not buts, it's blocked. What will probably end up happening is people who have invested in the Alientech JTAG hardware might be able to supply you with stock tunes for a fee (this involves pulling the ECM apart to read it). We are also looking at building up a library of stock tunes to offer via Tunedepot.
    Q - But I run a deleted tune from another tuner and I don't want to loose it.
    A - Can't help you out then sorry, we cannot read what is already in the ECM.
    Q - DPF, DEF, finally I can remove it all?
    A - Not with EFILive, well, not if you live in the USA. All tuning parameters related to DPF, DEF etc will be restricted from modification for USA customers right off the bat, no exceptions.
    Q - Well that sucks, no delete tunes!
    A - Times have changed and many tuners understand that you have to play by the rules these days. Already LML's are over 500 Hp with full emissions systems in place, this will only get better as tuning is enhanced.
    Q - DSP5 for the LML?
    A - Probably never going to happen. With the LML ECM Bosch really cranked up the security levels, the ECM's OS (where DSP5 mods would need to be made) cannot be altered by anyone outside of Bosch. They have some really complex security on the OS code that cannot be bypassed. However, Bosch kind of have a DSP5 mode built in, more on that later......
    Q - Will this support the LGH?
    A - Probably yes, but we have not looked at any LGH tunes yet. There was some subtle differences between the van and truck tunes on the old E35 ECM that caused a bit of a headache for us, hopefully this time around we won't have to face similar problems.
    Nov 2005
    Great work EFILive crew!
    So for LML customers outside of the USA, are there going to be EGR/DPF/SCR controls available?
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Not on initial release, but yes it is planned for non USA customers and trust me, it's not because people outside of the USA want to make trucks smoke, DEF just isn't available everywhere, pretty useless having a truck limited to 6 MPH because you've run out of DEF in the middle of the desert. I don't know, what is more important, not dying of thirst because your truck is in limp mode or saving a few grams of soot.
    EGR position controls will be in the USA release as these may become critical for emissions compliant tuning with parts modifications, but nothing to disable EGR DTC's should you remove it.
    Nov 2005
    Alright, makes sense.
    I assume full DTC reporting tables will be available too? (besides emissions-related DTC enablers for US customers) For example running standalone applications, MAF-less applications, etc...? Anti-theft/VATS settings?
    When you said "Bosch kind of added a DSP-5 built in", does that mean there are multiple different tables (effectively "DSP") that are selected based on various running conditions, or some non-essential sensor on the engine that could be "re-purposed" (IE, disconnect the sensor, and add a switch with a resistor ladder built in) as a "sort-of" DSP-5 switch?
    12.9s @ 108 mph
    Dec 2006
    Where can I get the Alientech JTAG hardware
    Apr 2007
    Thanks guys. A great day for us LML guys!
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    ...EFILive has indeed been working hard on the LML ECM to finally be able to offer you all a full tuning package just like the previous generation Duramax's. .
    Will stream licensing be available as it was with the previous generation duramax products?
    Custom Tuning Services
    That is the plan yes.
    I'm not going to say much at this stage because we need to do some testing, sorry.
    Quote Originally Posted by Duramax 6.6L View Post
    Google the name, it's from Europe. Don't quote me on this, but I think the full set up is nearing $12K.
    No stream for LML and what I meant by what you have quoted is the mapping/scanning is what you are familiar with on the previous models.
    Nov 2009
    Default LML full tuning, it's here!
    Awesome guys! This is freakin exciting... Can't wait to see how the market turns up these trucks. I knew you guys would let it rip sooner or later!
    Congrats again, very exciting!
    -Kory
    http://www.PPEI.com/
    Dec 2005
    You will also need a subscription and access to TIS.........
    www.mscservices.net
  1. Possible ways of tuning the LML?
    By THEFERMANATOR in forum Duramax 2011+ LML / LGH
    Last Post: August 2nd, 2013, 09:58 AM
  2. LML Flashing Support
    By cindy@efilive in forum Duramax 2011+ LML / LGH
    Last Post: August 2nd, 2013, 09:56 AM
  3. 2011 LML Duramax Tuning Please.
    By duramaximizer in forum Diesel
    Last Post: April 28th, 2011, 09:18 AM
  4. Lml / lgh
    By shay in forum Duramax 2011+ LML / LGH
    Last Post: March 10th, 2011, 12:41 PM
  5. LML TCM Tune
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: November 15th, 2010, 04:52 PM
