Results 1 to 10 of 14
Thread: question on autove and decelorating
    Jun 2003
    Default question on autove and decelorating
    When logging coming home today I am seeing during decel or coasting the aft going to 19+ and BE map for 3200x30map is at 1.6.
    I changed the filter to remove the decels, anyone think of reasons that would be a problem?
    It seems to me that in your filter you need to change the AND to OR.
    Do you have DFCO enabled...?
    Jun 2003
    step 5 in the autove tutorial says to have it enabled and set to 122c
    5. Open calibration {B3313} "DFCO Temp Enable" Set it to 122 °C
    my settings in the tune:
    LABELS Selection
    Parameters Value
    {B3307} DFCO Re-Enable Timer 5.000000 Seconds
    {B3308} DFCO M6 Enable Temp 50.000000 °C
    {B3309} DFCO M6 RPM 900.000000 RPM
    {B3310} DFCO M6 MAP 104.980469 kPa
    {B3311} DFCO M6 TPS 8.007813 %
    {B3312} DFCO M6 Speed 28.000000 MPH
    {B3313} DFCO Temp Enable 121.992188 °C
    {B3315} DFCO Vehicle Speed Hysteresis 2.000000 MPH
    {B3317} DFCO Throttle Hysteresis 0.996094 %
    {B3319} DFCO RPM Hysteresis 5.078125 RPM
    {B3321} DFCO MAP Hysteresis 0.996094 kPa
    Oct 2004
    Change B3308 to max temp as well, that is the DFCO M6 enable temp which looks like it is currently at 50.
    Andrew
    EFILive Crew
    Oct 2004
    Also if you want to filter out Decel try logging the Fuel Trim Cell # PID and then you can filter out FTC # 21 frames. FTC 21 = Decel
    Andrew
    EFILive Crew
    Jun 2005
    Quote Originally Posted by Tordne
    That's kinda what I do. I log FTC and tell it to exclude data cells where FTC > 19. That plus excluding data where TP% is changing more than 2% in 500ms usually gets me some nice numbers. One thing I want to try is to see what the IAT temp is the majority of the log and filter all data where IAT doesn't equal that number. I have a feeling this will also help keep numbers consistent.
    Jul 2005
    The easiest is to disable dfco completely. As the values in the ve table are in part derived from temperature the iat makes a huge difference.
    I make sure I keep it at a reasonable level the whole time I am logging and try and complete the tune in 1 go.
    Otherwise you have to have to exclude ce3lls that show a huge difference from the last adjustment.
    \"You Can Never Have Enough Horsepower\"
    Jun 2005
    Quote Originally Posted by caver
    Even with DFCO disabled, you still will hit the decel FTCs. It will affect your numbers...
    Jan 2005
    Quote Originally Posted by SSpdDmon
    That doesn't sound like it would work very well. In OLSD, you have FTC 20, 21, & 22. FTC>19 would exclude all data.
    Jun 2003
    Quote Originally Posted by TAQuickness
    Yup and thats what it does.
  1. question about autove
    By steve40 in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 02:40 AM
  2. AutoVe question
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2007, 10:52 AM
  3. Another AutoVe question....?
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2007, 03:43 PM
  4. AutoVE Map Question
    Last Post: December 17th, 2006, 11:55 AM
  5. AutoVe Question, Help!
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 28th, 2006, 04:18 AM
