Results 1 to 3 of 3
Thread: Vats won't relearn
    Senior Member auspeed's Avatar
    Jul 2010
    Default Vats won't relearn
    Hi,
    I have replaced the PCM and have tried to relink the vats in a HSV VY Clubsport.
    I have changed the vin with scan tool and tried to relink the vats....
    I makes 4 attempts to relink looking at the log. Then says auto-link bcm is enabled and
    recycling the ignition to relink. If it fails you may have to repeat the process. Which I have done numerous times without success....
    Anyone seen this or know why this I happening?
    You may have to cycle the ignition key at 10 minute intervals for at least 3 times
    (i.e. key ON, after 10 minutes security lamp starts flashing, key OFF... repeat (total 3 times);
    (at the very first key ON, you have to actually bump the starter (without letting it start))
    but I'm not sure how it Holden works on Holden.
    Jul 2010
    OK i got the car to start without ever seeing the message VATS re-link successful... I just assumed it worked.... However it ran it very very poorly & I'm confident that it wasn't tune related....... Not sure what was happening but it as though it was in a limp mode or something... I did perform a CASE relearn....
  1. Anyone have trouble with vats relearn on LMM
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 15th, 2012, 12:32 PM
  2. Vats
    By Yortt in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2010, 12:21 PM
  3. VATs question
    By Cougar281 in forum General (Diesel)
    Last Post: June 18th, 2009, 08:29 AM
  4. 97 Corvette VATS
    By tracykeyes in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2006, 02:33 AM
