Results 1 to 10 of 12
Thread: Cant log with v2 ?works ok with passthrough ??
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    Default Cant log with v2 ?works ok with passthrough ??
    HI guys
    my friend is having trouble logging with v2 standalone ? it logs ok with pass through to his laptop
    any help would be appreciated
    things we have tried
    have updated all the firmware / boot block several times in the last month
    formatted the memory and the SD card and reprogramed with all dater in BBX
    thanks
    What happens...?
    Do you have BBx configured for the ECMs you want to log...?
    What ECM is this failing on...?
    Post a screenshot of the BBX page of the V8 S&T software.
    Aug 2008
    as far as i know it just doesent log ??
    sorrey he dident give any more deatails
    ill have to get him to fill me in on the deatails of weather it displays a msg or a failuer notice
    im going to try and log it ( E38 ) with my v2 on the week end
    thanks
    Aug 2008
Name:	v2 pid bbx list.png
    here is pid list and ECM page he sent me
    sorrey for double post
    Aug 2008
    here is a page shot of the pid list and ECM list
    he sent when he was programing the v2 about an hour ago
    Aug 2008
    he said
    It just says creating log file
    And stays like that wont do any more and I have to unplug it
    Can't read tunes either says it unlocking and same thing just stays like that even when the fault codes " contact dealer " are flashing on dash
    Aug 2008
    any ideas on this guys ??
    Make sure the PIDs he's using are compatible with his OS/ECM, if they aren't it will error out and say something like it cannot log.
    Then Id format the config and filesystem, and start over. Ive had a few issues where I thought everything was setup but after starting from scratch it worked just fine. Download the latest beta stuff from the forum, wipe the config and filesystem, then use the BBX settings window to copy the right stuff over.
    Aug 2008
    thanks ill pass it on to him
  1. Weired LS1 Passthrough Log
    By swingtan in forum General
    Last Post: July 2nd, 2010, 11:48 AM
  2. LBZ/LMM Passthrough issues
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 3rd, 2010, 11:55 PM
  3. V2 in passthrough mode
    By Tre-Cool in forum FlashScan V2
    Last Post: January 15th, 2010, 04:16 AM
  4. Can't scan LLY in passthrough
    By Cougar281 in forum Diesel
    Last Post: October 17th, 2008, 02:54 PM
  5. Passthrough data logging problems
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: November 28th, 2007, 04:23 PM
