It would appear there is no table inside the 4l80E transmission tune to change the base transmission pressure (idle) via the PCS.
Why is this table not available? I would think there has to be a load vs temp table the PCM is looking up...
Issue I am having has to do with a transbrake I bought for this trans that uses the internal brake circuit to engage Reverse. Long story short, the spring on this circuit was too weak and the brake activated at 30mph on the road, so I tore it apart and changed the spring out to a heavier spring. Problem now is on cold mornings I can't get the brake to activate (Go in reverse) until the trans warms up. Basicly I need the PCS to command higher line pressures at colder temps.
Anyone know of a work around for this? I may just have to change the spring to a lighter one, but really wanted a quicker work around!
Thanks.
