first run with fault.efifirst run with fault.efiRighto, update. The tranny is doing everything it need to. All the diagrams I had didn't have the brake circuit on them!lol
Cheers joecar for your patience. Im sure you must get the shits with noobs like me, but im learning! Ill have to do some tuning on the shoft points they are soft and am actually too scared to let it do a wide open shift as it takes a while.
I still have a intermittent fault which causes the car to run rough, more throttle and it cleans up but its weird, you can leave the throttle alone at a steady 80k and all of a sudden it cleans up and it runs almost normal. I haven't got the purge setup yet, but its still throwing the o2 codes. Both high and low voltage. Maybe one of my brand new bosch sensors have failed? The fuel trims are showing a - on that bank that plays up and around 23 on the other. I data logged a bit of the run , ill see if I can post it
