Results 1 to 7 of 7
Thread: Locked tune...
    Jan 2013
    Default Locked tune...
    I had a custom tune done to my truck while out of town. Now the computer of the truck is locked, its running lean 15.4:1 and some sometimes 17:1. there is a dead spots a 5000rmp and misses a bit till 5400rpm then it wakes up and sets you back in the seat. run slightly rough at idle (950rpm). Its a gmc yukon Denali with a 6.2l vvt comp cam, biggest they make. Ported heads and kooks headers. Comp cams valves springs and lifters and push rods. Any one have any ideas or do i need to get another computer. P.S. when accellerating heavily its is at 12.8:1
    I moved your post to the GenIV section...
    Can't you take it back to get the tune revised?
    Jan 2013
    Yes and I will but I am 1200miles away visiting my sick father. Any ways I pIcked up another computer and put the old tune back in. It's a 2l per 100 km harder on fuel but at least I don't have to worry about it running lean. I did make changes to it for the 1 7/8 kooks headers and off road cat less y pipes. What is the safe limit for air fuel ratio? His tune runs at 15.1:1 normally on the highway till I do wot then it hits 12.3:1. I got nervous in the city stuck in traffic it leaned out while sitting there idling to 17:4.
    Jul 2005
    I question the accuracy of any wideband O2 sensor at idle. I talked with Ed Wright about this same subject.
    You could have run high octane fuel til your retune. I wouldnt worry much unless you were under load.
    peace
    Hog
    1997 rcsb stock L31 longblock, Marine Intake with 28# EV6 injectors, L35 2700 stall TC,Hooker LT's 2.007 60ft
    Jan 2013
    15:1 normal on the highway?
    Lifetime Member EagleMark's Avatar
    Dec 2010
    15.1 AFR, if accurate, would be safe in lean cruise. Can't see how that could be accurate Closed Loop? Even if it were non ethanol...
    Set up your wide band properly for Lambda.
  1. Installing Locked Tune With V2
    By Kiwi Ed in forum FlashScan V2
    Last Post: August 12th, 2012, 08:06 PM
  2. can't download my tune, could it be locked?
    By alwaysinboost in forum FlashScan V2
    Last Post: May 1st, 2009, 03:10 PM
  3. Tune locked, can't read?
    By eboggs_jkvl in forum FlashScan V2
    Last Post: January 31st, 2007, 03:52 AM
  4. Locked Out!
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2006, 12:38 PM
  5. 98's (Locked)
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2005, 08:54 AM
