Gents,
Have a 2009 L9H / LS3 truck motor in a 11' JK
Having some slight knock retard issues when lugging the motor either on highway or back roads. Almost always when the truck is in 6th gear turning along and maintaining speed with throttle input without down shift.
Seeing 1-8* at varying conditions 1200-2000 rpm & 0.32 -.56 Grams/cyl
Fueling is good - Showing .96 - 1.0 Lambda at all ranges - Zero KR when "on the throttle" or WOT
So My Question.
I understand that you should look to take the highest knock count for the specific cell and divide by 2 and subtract that amount from the spark table and see how that effects the KR..
My question is do you blend the surrounding cells a bit or if they are not effected OR leave them alone? I didn't know if its ok to have a 4* difference in one cell with full timing value on the adjacent??? Kinda gives you the up and down scenario.
I would think that with normal driving you would be all over the table anyway and never transitioning across or through adjacent cell in a linear fashion negating the need for smoothing, but I want your opinion and expertise.
I have tested this by decreasing spark and eliminating the KR in some areas so I believe most of this is actual knock along with some drive train noise..
Respectfully,
John
