i changed these values check pedal position and axis i changed pedal got a little better also changed limiter
Your pedal position was fine, no need to change the axis. Its all in table F0502 and pw.
how do you flash with the smarty tune? can you just steal the tune by reading the ecm with out messing anything up? I would love to see what smarty is doing on a few areas just so I can learn thanks
