i appreciate the honesty, i don't know logging this is all new to me. I assure you this is a 100% stock vehicle this happens key cycle to key cycle. The last logs i gave you had no surging issues the logs prior to that had surging. i bet if i went out and logged again there wouldn't be surging. The blimps in the throttle position are where i had to let off the throttle in order for the transmission to shift up a gear.
My only codes are for a bad #8 glow plug and front right and left wheel sensors that is all. Im sorry about my logging once again im new to this side of it, ill get some more reading done and post something use full. I do not have a vin license yet for this truck do you think flashing in a stock or performance tune might clear this up?
I do appreciate your help tho! Thanks
