Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Bad Flash (possible bricked ecu)
    Aug 2012
    Default Bad Flash (possible bricked ecu)
    I went to full flash my ecu as i was going to change my operating system. Apparently a past issue came back to haunt me and during the flash it just stopped. I had updated to the new version with the fixed issues and the handheld and software are working fine. I try to cal flash and full flash my original file back in my truck and it cannot connect with the truck and will not start.
    I do have access to GM tech 2 and bench flasher so i could pull my ecu and reflash it (Do you guys think this will fix it, Or do you think the ecu is dead?)
    I did notice my 3rd tick on the handheld settings with the truck was never lit up in green. Wasn't there a way to get it to connect again I thought? I have 2 green X's out of the 3. If so i hope i could just flash my cal again and get it running.
    Thanks Guys
    Aug 2010
    What controller are you working with ?
    Post the tune you tried to flash (when the issue occurred).
    Aug 2012
    Its a LS1B from my 2001 truck. I was upgrading to a Camaro file so I can flash in COS5. I was flashing with V8 and it failed. I then noticed i was having the issue with v7 and having my handheld plugged in where it would freeze (had this problem before), Found there was an update here on the forum to fix the problem (when ever i tried to update through the software it never found this update fix). SO i fixed the handheld and software with the update and firmware etc. I went to flash in my file i used previously on my truck and nothing it wont communicate with the truck.
    I did notice I had 2 green X's out of the 3.
    I am at work or else i would post the files.
    Oct 2006
    When you full flash the most critical part is the first few seconds (erasing memory), after that the PCM is recoverable.
    Try taking the negative battery cable off for a few minutes, then put it back on and try again.
    2006 Trailblazer
    Lifetime Member EagleMark's Avatar
    Dec 2010
    I think the most critical part of a full flash is always do it on bench! Not in vehicle.
    When I brought up the topic of Bricked PCMs there was no absolute positive list of what PCM or YMM could or could not be full flash. The issue was other modules on data line loosing contact with mothership causing the flash failure and Bricked door stop PCM.
    Since using this advice I have never bricked a PCM...
    Aug 2012
    I will full flash for now on on the bench. I will try disconnecting the battery and re flashing it again to see if i can get it to start. If not im pulling the ecm and bench flashing it with the tech 2.
    I attached my map that i have ran in my truck for almost a year now. I also attached the file i was converting and flashing in.
    Here is what im talking about with the handheld. It wont communicate with the ecu (hoping its not dead) im going to try a few more things also before pulling the ecu out to bench flash.
Name:	efi live hand held.jpg
    If the PCM is recoverable, then when you connect FlashScan to the vehicle one of the orange LEDs on FlashScan's keypad will flash 4 times per second. That is the PCM polling with an "is anyone out there" message. Its what we call dead-poll, the PCM is "brain dead" but it is looking for (i.e polling for) a scan tool that can reprogram it.
    If you don't see that LED flashing 4 times per second (i.e. it only flashes sporadically, or not at all) then either the PCM is OK or it is 100% dead and unrecoverable. Given that you don't get the third green tick, chances are that it is really a door stop now.
    As Chevy366 said the first few seconds are the most critical. If the full flash fails after the PCM is erased but before the communications firmware is reprogrammed then the PCM will not be able to communicate with the scan tool to facilitate any sort of recovery. If the comms firmware made it back in before it failed then it should be recoverable. It is that comms firmware that does the polling which causes the orange LED to flash 4 times per second.
    If it really is now a door stop, here are some things to keep in mind:
    1. You can send it away to be repaired. That involves removing the flash chip from the main circuit board, programming it in a chip programmer and re-soldering the chip to the board.
    2. If you choose to replace the PCM with another make sure you get a receipt, then send the receipt to EFILive, we'll replace your VIN license free of charge.
    Aug 2012
    I just went out to check. I plugged in the V2. all lights flash as its powering up. then there is 1 flash on the right orange led. when turning the key on it flashs really fast, then when turning the key off it flashes 7 times at a nice even pace then stops. So are you saying its a 50/50 chance its dead.
    I can de solder and resolder a chip no problem in the pcm but I am unsure of the chip if i have any way to burn it with my burners and also wouldnt i need software to transfer to a new chip.
    Im going to see if i can bench flash it tomorrow back to stock and if not guess i will have to buy a new pcm and flash it on the bench.
    Quote Originally Posted by FreshDA9 View Post
    The initial flash is FlashScan looking for what modules are on the bus.
    The really fast flashing at ignition on is caused by each module on the bus attempting to communicate with the ECM (and/or with each other) to try and establish which modules are operational and available.
    The final few flashes are most likely the modules that did "discover" each other sending each other messages.
    If the flashing stops completely, then the PCM is not sending out its polling message, which indicates that wither its 100% dead or it is operating normally and doesn't need to send out the poll messages. But given the vehicle won't start and you don't get the third green tick the most likely explanation is that its not operating normally and is actually 100% dead.
    If you want to try and reprogram the chip yourself, I can supply you a binary image for the chip from the file that you posted. Send me an email at paul@efilive.com and I'll email it back to you.
    Aug 2012
    Ill pray that it goes well on the bench tomorrow. if not then I will probably order one and flash it to get my truck running again. Then i will take this one apart and reset the chip.
  1. HELP!! FLASH GONE BAD! Have i bricked my ECM?!
    By TravelinCummins in forum Cummins 5.9L
    Last Post: September 11th, 2013, 04:52 PM
  2. Bricked The V2??
    By RobsDmax in forum FlashScan V2
    Last Post: July 24th, 2013, 09:53 AM
  3. Cant Read ECU after EFI Live Flash
    By akcooper9 in forum Gen III V8 Specific
    Last Post: December 13th, 2012, 05:06 AM
  4. Bricked H3... almost
    By SwedeBurb in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 13th, 2012, 10:33 AM
  5. have to flash ECU forProject GenIV "LMG" into 1997 Tahoe
    By harascho in forum Gen IV V8 Specific
    Last Post: April 14th, 2008, 02:55 PM
