Results 1 to 7 of 7
Thread: Build Boost While Staging
    Jun 2005
    Default Build Boost While Staging
    I was wondering if anyone knew a way to build boost while staging at the track. Currently while just using the footbrake all I can muster is 2-5in of vaccum. Getting a measly 1.80 60ft but car pulls hard after that. If I can only get the car to launch harder with some boost off the line I will be able to lower my ET's!!!
    I read somewhere about wiring up a relay to the ait sensor to interupt it so the car will read -39 degrees and pulling timing in the lowest area, of the AIT timing table.
    I did a test and just pulled the ait sensor saved a file with pulling timing in the ait spark table, and it seemed like the turbos wanted to spool, however right about 0 the car was stumbling and falling on its face.
    Any insight fella's?
    2000 Corvette Twin Turbo
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
    Jun 2005
    If you have a vacuum assist brake set up, you can do the Sy/Ty Shuffle:
    1) Put the car in neutral with your foot on the brakes and rev to 4-5000 rpm
    2) as the rpms fall press down and the pedal will drop some more as the vacuum shoots up
    3) keep the brake firmly pressed and put it in gear -- I can build as much boost as I've tested this way.
    Hello, my name is Erik and I am a horsepower addict...
    Mar 2005
    Hard to do that in a manual
    Jun 2005
    Quote Originally Posted by jsttry
    Yep it would be -- good think both VetteBoy and I have autos
    Jul 2005
    Methinks the new n2o operating system will do the trick for you.
    Retard the timing by like 30 deg and dump some fuel. I have seen .5bar boost at 2000rpm on a Sentra turbo doing that.
    Not to healthy for the turbo of course
    \"You Can Never Have Enough Horsepower\"
    What stall converter do you have in the car?
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jun 2005
    Its a PRO YANK 3200 EXTREME
    So me thinks that I need to throw some more fuel at it when the timing is being pulled, and maybe that will stop the motor from falling on its face and instead create some boost on the staging line.
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
  1. Build 88
    By Gordy M in forum General (Petrol, Gas, Ethanol)
    Last Post: December 1st, 2009, 08:07 AM
  2. Replies: 50
    Last Post: March 15th, 2009, 03:00 PM
  3. build 80 and 78 ?
    By JST in forum FlashScan V2
    Last Post: February 11th, 2009, 11:59 AM
  4. DSP5 Staging addition?
    By Cougar281 in forum Duramax LLY
    Last Post: June 29th, 2007, 12:51 AM
  5. how to build map to log boost?
    By minytrker in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 23rd, 2006, 09:54 PM
