Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Not showing file analysis - B9999 OK to flash?
    Dec 2011
    Default Not showing file analysis - B9999 OK to flash?
    When I open a tune file in V7.5, on the bottom of the details section it is not showing B9999 Tune File Analysis, so I don't know if the file is OK to flash. I have opened known good stock files and modified files, but nothing shows down there. Is there something I'm missing? I'm running the latest version of 7.5.
    Thanks for any help!
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Default Re: Not showing file analysis - B9999 OK to flash?
    I have some trucks that are like that. I haven't had any issues with flashing them. If I remember right when I changed os from tunefiledepot thats what it does.
    It should show for every OS, what numbers have you seen it missing on?
    Dec 2011
    Every one I've tried. Primarily 11450202 and 11352409, but I also tried other random ones (e.g. 11501001 and 11551031) just to see if I could get it to come up. I also thought it might be the computer/installation, so I loaded EFI Live on another computer and had the same issue.
    Jun 2011
    Im using 409 and I believe B9999 comes up but thats it. It doesn't say anything about ok to flash.
    Nov 2010
    Quote Originally Posted by jqc99 View Post
    Are you not seeing them after upgrading to csp os?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Dec 2011
    I don't think I'm running the V7.5 version that has the option to upgrade to csp- I thought that was still in beta. I'm running 7.5.7 build 235.
    Jun 2011
    Quote Originally Posted by 2007 5.9 View Post
    It has happened pre csp and post for me. I have only found it to happen after changing OS on a truck that previously had a smarty or doing an OS change. I haven't had any issues with it. I guess I just really haven't paid any attention to it.
    Latest software with CSP can be found here.
    http://forum.efilive.com/showthread.php?t=23025
    CSP5 is still in public beta, there is one more update coming before it goes to public, there was some people report the pilot timing PID's in the EDA data was not correctly showing values for some OS's, that is fixed and will require a full update.
    Dec 2011
    I just upgraded to the CSP5 beta and I still do not show the B9999. Any ideas?
  1. so i went to flash in a file and its a no go????
    By C Murda in forum Cummins 6.7L
    Last Post: May 10th, 2013, 12:16 AM
  2. Replies: 5
    Last Post: October 1st, 2012, 12:42 PM
  3. Trailbalzer red the file but refused to flash and the car won't start again
    By odd boy in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: October 29th, 2011, 01:59 PM
  4. Can't BBX full flash (Error $0502, script file not found)
    By spandit in forum FlashScan V2 BB Logging
    Last Post: April 14th, 2011, 09:34 AM
  5. any reason why my flash wont work on car after i close the tuning file
    By z28ls1818 in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 12th, 2010, 02:40 PM
