So why not just carry on with tuning...if you know you have a good file, why beat yourself up over it?
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
Post one of the stock files you have issues with and lets see if Les and I can open it.
Cheers
Cindy
Cindy- The stock file I have came from Les!
Les- I'm just starting to learn about tuning and I wanted to make sure an adjustments I do will still show an ok to flash. And if I ever pick up any other tunes I'd like to make sure they were ok too.
Adjustments you make won't change the "Ok to flash".
That only changes when the file is initially corrupted.
So as long as you use files told to be clean or from those you trust...I'd continue on with tuning and start enjoying your labors.
Les Szmidt
2007 5.9 Dodge Ram
Ah ok... I didn't know that. I thought you had to make sure you always had the "ok to flash" and it wasn't just dependent on the initial file. Thanks!
I did figure out why I wasn't showing B9999 and got it fixed though. I just had to get it figured out- something in my nature...
What was causing it?
Les Szmidt
2007 5.9 Dodge Ram
For some reason my cal_summary file was missing. Without it, EFI doesn't load B9999 upon opening and I didn't find a way to bring it up after the fact.
