Results 1 to 2 of 2
Thread: Reduced power mode at 217 degrees
    Apr 2012
    Default Reduced power mode at 217 degrees
    I've got a weird symptom that has me pulling my hair out! The engine is a 5.3L with a manual transmission behind it. It's in a Jeep with A/C. The engine runs flawlessly, runs cool...around 195-205. Once the engine is up to temp and parked...it will heat soak. Once the engine reaches 217 degrees and you start it, it will idle up and instantly go into reduced power mode. I thought it had something do do with "Fan power vs ECT" but after playing with it in every direction, it still goes in PR at 217. The radiator only has a single fan on it. Am I missing something with the fan settings? What else would cause PR mode at exactly 217??? Any help or ideas is greatly appreciated!
    Apr 2012
    Anybody??
  1. 07.5 lmm goes into reduced power mode
    By da-sparky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 29th, 2011, 11:47 AM
  2. Reduced power mode Again!...........
    By FreddyG in forum Gen III V8 Specific
    Last Post: November 16th, 2007, 08:08 PM
  3. Reduced Power Mode...............
    Last Post: November 13th, 2007, 06:13 PM
  4. reduced power mode
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2007, 03:12 PM
Tags for this Thread
