Results 1 to 6 of 6
Thread: licensed controller says it not??
    Jul 2013
    Default licensed controller says it not??
    i licenced a controller for a 2004 and 9044 os ,,, changed to a 6006 os and tryed to make a change and now efi says controller not licensed with a $0534 message?? any ideas what i did,,, pritty sure i didnt lock it
    Nov 2005
    From the Error Code list
    $0534 Invalid Serial Number.
    An attempt was made to program and license a controller that had a corrupt serial number.
    It is possible for the serial number to appear corrupt due to a data transfer failure. Retry the operation a few times, if the error continues to occur then the serial number probably is corrupt. In that case, use the EFILive Tuning Tool software to full-flash the controller to restore the serial number.
    What serial number appears?
    Cheers
    Cindy
    Jul 2013
    tried it a couple more time and it says the same thing ,,, the number it says is 3280ct09bcp1
    Nov 2005
    I've escalated your issue to support.
    Cheers
    Cindy
    Make sure you are using the latest EFILive software, available here:
    http://forum.efilive.com/showthread....te-Aug-06-2013
    Then if the problem still occurs, please locate the appropriate trace files as per the instructions here:
    http://support.efilive.com/kb_articl...8254-QOGC-9586
    Send the trace files to me at paul@efilive.com
    Jul 2013
    that did it guys ,,,thanks a bunch!
  1. Replies: 4
    Last Post: January 3rd, 2013, 08:15 PM
  2. Licensed ECM can be retune with another v2???
    By 400ss in forum Gen III V8 Specific
    Last Post: May 30th, 2012, 05:27 AM
  3. Replies: 4
    Last Post: September 10th, 2010, 01:38 PM
  4. help needed...pcm asking to be licensed again
    By steve40 in forum General
    Last Post: June 16th, 2010, 01:51 PM
  5. Licensed PCM now unlicensed?
    By PSWired in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 08:43 PM
