Post your calc_pids.txt file here.
Hi All,
I used my V2 to log some data on Friday without any issues, when I went and plugged the V2 into my Laptop it asked for Firmware to be upgraded, which I did, as the V2 hasn't been used for some time. I upgraded the Book Block to 2.07.06 and Firmware to 2.07.49 as it came up in the upgrade window, now when I plug my V2 into my laptop or into my car (E38) it comes up with Error $0482, I can't return to a prior version of the firmware to try and resolve the issue, how do I get it working again as I can't do anything at all with it in relation to tuning or logging data.
Cheers
Fixed the issue, found another thread on here and followed what was outlined,
http://forum.efilive.com/showthread....=Error+%240482
Cheers
I never received your email. Could you please resend it to paul@efilive.com
can not start software on my desktop either scan or tunesame error message
C:\Users\TONY\Documents\EFILive\V7.5\User Configuration\calc_pids.txt(58): Units /(displacement()*{SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTF TBEN}" not found. .
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
None None "" "No units"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
*CLC-00-001
% -25.0 25.0 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2"
*CLC-00-002
factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT2})/200+1"
*CLC-00-003
% 0.0 100.0 .2 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*3445. 2
VE 0.0 3.0 .4 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*1 5
/({SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFTBEN}"
CALC.LTFT F001 CLC-00-001 % Tuning "LTFT Average"
CALC.LTFTBEN F002 CLC-00-002 factor Tuning "LTFT BEN"
CALC.VE_Table F003 CLC-00-003 % Tuning "CALC VE Table"
Sent again from a different email this time. let me know if you get them thanks.
2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
1984 CJ7 powered by a 2000 LS1. 4L60E.
2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
2003 Jetta TDI,
1986 K10 LQ4/4L80E
durrr I fixed it, I did an uninstall again but this time I checked to see if the folder efilive 7.5 was removed and it was not so I deleted that and then reinstalled and that did it I am all set thanks.
I just purchased a newer laptop. Installed the newest. V7 software v7.5.7 build 241 V8 software v8.2.2 build 234 Bootblock V2.07.06 july 31,2013. Firmware V2.07.49 Aug 02 2013. Went fine. The problem is my firmware says Aug 02, 2023. Is that correct Why am I at 2023 on my flashscan when the date should be 2013. Again my firmware now reads V2.07.49 Aug 02, 2023 ???
1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
ok thanks
