Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: Running Discrete Fan with Vette Tune
  1. #51
    Jul 2012
    Quote Originally Posted by LastCall View Post
    Did it work?
    YES, it worked well. THANKS!
  2. #52
    Mar 2009
    Quote Originally Posted by Hocky View Post
    Here is my tune.
    Thanks for giving it a try!
    ...and as you can see in the filename I also have trouble with the speedo not working
    Try the attached.
  3. #53
    Jul 2007
    any one able to fix this one for me??
    its been frustrating!!!E38 jeep corvette new.ctz
  4. #54
    Nov 2008
    Try the attached.
    I will have a try next week, got some other things I had to do first...as putting the car back together from paint
    I did try to open the file with the latest version of EFILive Tune 7.5.9 (build 320) and I get an error message that the file is saved with a more recent version? Is there any newer version available and what version did you use?
    Thanks alot for giving it a try!!
  5. #55
  6. #56
    Jul 2012
    Is this issue something we can expect to be corrected in an upcoming update? I really hope it can be.
  7. #57
    Member koolky's Avatar
    Aug 2013
    Quote Originally Posted by proflash View Post
    Try this:
    E38 jeep corvette new_0000.ctz
  8. #58
    Nov 2008
    Try the attached.
    It worked, now I got in control over when the fan is on/off!
    Really kind of you helping me with this irritating problem!
    Do you got any PP or something so I can give you something for it, just PM me it if you want
    Thanks once again!!
  9. #59
    Jul 2012
    Quote Originally Posted by LS-SWAPPER View Post
    Well, I spoke too soon. The vehicle has been driving around the parking lot getting other parts of the build finished for a few week. The other day it got driven a little more...no shifting out of 1st gear. I went back and looked at the file (that works the fans properly) and it says its for a 6L80e. The original tune I was working with was for the t42 4L80e setup. Darn...so I guess I'm back to the drawing board.
    I looked into it further, I cannot make a trans segment swap in this case, but I can make a "system" swap. Can someone enlighten me as to what that includes exactly? What would I be swapping over? Is there any chance I can just swap the system with the properly working fans into the tune with the properly working transmission? Obviously I'm going to try it anyway, I would love a little more in depth info so I can learn.
    Lastcall I appreciate your help with this, its not your responsibility I know but if you would like to PM me for any reason that would be great. If not, I do appreciate you helping me with the issue up to this point.
  10. #60
    Aug 2013
    LS-SWAPPER, try this file. I made the changes to your file from post #42. It's not segment swapped.
    2008 LS3 E38 for t42 12617631_0000.ctz
  1. Stock 04 Vette tune
    By spiderpat in forum Gen III V8 Specific
    Last Post: September 14th, 2012, 08:27 PM
  2. adding electric fan to TBSS, need help with tune
    By Boost in forum Gen IV V8 Specific
    Last Post: May 4th, 2011, 12:54 AM
  3. Cammed Vette, can't do WOT tune....
    By The Cartel in forum Gen III V8 Specific
    Last Post: July 23rd, 2008, 02:51 PM
  4. 04 Vette A4 tune file
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: March 14th, 2007, 02:21 AM
  5. Taurus fan kills idle, How to tune?
    By DaleMX in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 06:34 PM
