Results 1 to 4 of 4
Thread: Got new LS1B ECU for truck from junkyard to replace bricked one, and have some ???s
    Jan 2013
    Question Got new LS1B ECU for truck from junkyard to replace bricked one, and have some ???s
    I attempted to just straight off read the ECU and it said error $0281 something about no data received.
    1. Do I need to do the relink VATS thing 10 mins on, 20 seconds off, 3 times first? Or is this PCM dead too?
    2. The ECU is also a 2001 instead of 2002 like before, do I lose any tuneability, for the lower year?
    3. And what is the best way to convert the tune I have from 2002 to 2001 OS?
    Quote Originally Posted by sac811 View Post
    That's not a good sign, how was the PCM powered and connected to the FlashScan? Was it hooked up to the vehicle's harness or were you using a bench harness?
    Make sure the cigarette lighter fuse is ok, that powers the OBDII copnnector.
    No.
    Full flash your tune into the new PCM. I highly recommend making sure you can cal-flash it and read it back out again (multiple times) first before attempting any full-flash.
    You will eventually need to perform a VATs relink or disable VATs (before the engine can be started) but not being linked will not prevent reading/flashing the controller.
    Jan 2013
    The new ecu was thru harness...so guessing new ecu is dead.
  1. Bad Flash (possible bricked ecu)
    By FreshDA9 in forum General
    Last Post: August 23rd, 2013, 07:46 AM
  2. Replies: 0
    Last Post: November 10th, 2012, 11:43 AM
  3. Replace NB w/WB or just add?
    By Garry in forum General
    Last Post: June 24th, 2006, 05:44 AM
  4. 1999 O2 replace suggestions
    By Rico in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2006, 11:52 AM
