Results 1 to 7 of 7
Thread: Fuel smell at idle
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Default Fuel smell at idle
    OK this has been covered a million times. But the typical idle smell is happening.
    The cam is not very big, #s are .613/.576 227/234 115, this has very little overlap. When I make idle around 16:1 the smell goes away. But as soon as I set it back to 14.7 or turn on the o2 sensors which switch around 14.7 it gets a little smelly again.
    Is this just something that can't be fixed or does it seem like there is a mechanical problem with the car? That cam profile is odd to me so I'm not sure what to think. Stock LS6 with headers exhaust etc.. I won't lose any sleep over it if there is nothing to be looking at.
    Jan 2007
    BUMP
    The cam had a bunch of advance ground into it which may have had something to do with it. I got it a lot better but the fuel trims don't make me real happy at idle. That car runs and drives great.
    But for reference. Is there a trick I'm missing? I have't played with closed loop proportional idle tables, will that help?
    Oct 2006
    I found that my best idle stability was around 15.6:1 & kept closed loop turned off around idle. (I use a COS & use semi closed loop) If I allowed trims to be active I would also get the fuel smell & idle quality wasnt great.
    Give it what it likes instead of trying to hit a number & you will both be happier..
    The Tremor at AIR
    Jan 2007
    I think that's a great way to do it for a lot of applications. But for MAF enabled CL I don't think that is possible is it?
    Oct 2006
    You could lower the O2 switchpoints in the idle areas, which will keep it leaner.
    Also you can run a COS & retain the maf.
    The Tremor at AIR
    Jan 2007
    I'll have to look into lowering the switch points in the idle areas. Haven't played with that. Thanks
    Lifetime Member Boost's Avatar
    Dec 2006
    Subscribed ������
    8.7 @ 84 (1/8 mile) bolt-ons
  1. Unexplained lope at idle. Fuel Pressure Reg?
    By hepperj27 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 30th, 2012, 10:45 AM
  2. Replies: 18
    Last Post: February 27th, 2011, 06:20 PM
  3. can not set idle to correct fuel mixture
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 15th, 2009, 02:46 PM
  4. 05 GTO idle/fuel problem
    By slowhawk in forum Gen IV V8 Specific
    Last Post: March 30th, 2008, 12:36 PM
  5. idle fuel efficiency?
    By turboberserker in forum Custom Operating Systems
    Last Post: February 16th, 2006, 06:13 PM
