bump
bump
Why bump this after 3 years? The software and firmware changes between the software that customer was running, and what you should be running are completely different. The error code in the original post is not a current EFILive error code, so if you are getting that error code, please make sure you are running the latest software (RC1 dated June 2016) and try again.
The error code master list can be found in V8 Scan and Tune software. Open V8, Select [F8: Tools] -> [F8: Error Codes]
Cindy
