Results 1 to 4 of 4
Thread: P12 Colorado Flash Fail
    Dec 2006
    Default P12 Colorado Flash Fail
    I tried to flash a cal only into a 2005 Colorado and with the V7 software the flash failed. It looked like the calibration was completely loaded and then I received the error code of $0673. Tried several times with V7 and the flash did the same thing with the progress bar on the bottom showing complete, but then throwing the error code again $0673. I then tried to flash the cal file with the V8 software and it worked perfectly with no issues.
    What is the error and is there a master list for error codes any where.
    Thanks in advance.
    Regards,
    Frank
    2007 LBZ 2011 LML Silverado Pickups
    2015 GMC Denali 3500 Dually Diesel Pickup
    2007 Dodge 6.7 Pickup
    Oct 2014
    bump
    Nov 2005
    Quote Originally Posted by kajon25 View Post
    bump
    Why bump this after 3 years? The software and firmware changes between the software that customer was running, and what you should be running are completely different. The error code in the original post is not a current EFILive error code, so if you are getting that error code, please make sure you are running the latest software (RC1 dated June 2016) and try again.
    The error code master list can be found in V8 Scan and Tune software. Open V8, Select [F8: Tools] -> [F8: Error Codes]
    Cindy
    Oct 2014
    I needed to get above ten posts so I just bumped it real quick sorry to waste your time
  1. I need a stock file for i4 p12 2004 colorado 5sp
    By Garth@undercover in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 19th, 2013, 07:34 AM
  2. Colorado P12 3.5 tune
    By hondarider552 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2012, 11:58 PM
  3. P12 chevy colorado ecm
    Last Post: June 19th, 2011, 05:18 PM
  4. If you fail to plan, you plan to fail!!
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2009, 06:02 AM
  5. 2005 colorado I5 flash problems
    By nonnieselman in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: July 9th, 2008, 04:00 PM
