Can you look at my tune to see what im missing
Sure. Email it to me if you want. Dwrobb99@yahoo.com
05 Joe Gibbs black RCSB ram air hood, Leer tonneau, blacked out tail and head lights. Forged 370, Eagle crank, Wiseco pistons, Compstar Rods, Pro Flo XT intake, KB Racing log, spool valve, T6 S480 1.32 A/R, boost activated cutout, TSP 2.5 5.3l heads, Comp Cam 224/230 .600 with rockers, comp cams 1.75 roller rockers, dual Walbro 450's, Injector Dynamics id1300's, 4l80e w/3200 multidisk Circle D, trutrac w/3.73's, 3"DI/DO Magnaflow, tips through the roll pan, running COS3 Semi OLSD OS#12592618
So my pcm will read my sensor just need to do the swap?
Ok just found a l59 with same os and did a segment swap engine calibrations is that what i needed
That should work. I saw a flex fuel version for a Tahoe.
Thats what i found too engine segment is what i need isn't it
Thanks it works now
