Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 24x reluctor for Vortec truck apps
    Jul 2005
    Are you up and running already on the 0411 on your L31? You are probably running some sort of 01-02 L31 express van calibration now.
    If you are running a cable throttle, you will use a Camaro LS1 calibration as teh LS1 Camaros run cable throttle.
    If using ETC you will run a Vette LS1 calibration as the LS1 Vettes run ETC.
    peace
    Hog
    Aug 2012
    Will that tune support 4x4 low, AC request, etc? Is 4x4 low signal even necessary for pcm?
    Also, which tables do I need to change if starting with the ls1 tune?
    Aug 2012
    And yes, I have been up and running for two years. I'm just sick of the missing and p0300's.
    Jul 2005
    Quote Originally Posted by bubba68ss View Post
    You will require some work for proper 4Lo shifting. Its all been done before around here.
    peace
    Hog
  1. Replies: 5
    Last Post: December 28th, 2011, 01:07 PM
  2. 50% APPS / 100% TPS w/ DBW. WTH. LOL. HELP!!!
    By wayneosan in forum Gen III V8 Specific
    Last Post: August 20th, 2011, 05:11 AM
  3. 4x Reluctor
    By doubledip in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2010, 02:55 AM
  4. Holden V8 - reluctor 24x with LS1 PCM
    By Batman in forum Conversions / Aftermarket Parts
    Last Post: July 21st, 2009, 05:36 AM
  5. crank relearn on 97 L31 vortec truck?
    By sean3393 in forum General
    Last Post: July 31st, 2007, 06:29 PM
