Results 1 to 5 of 5
Thread: GM.BOOST_DMA not available as a BBL PID for E60 controller?
    Senior Member thunder550's Avatar
    Default GM.BOOST_DMA not available as a BBL PID for E60 controller?
    I'm trying to get my V2 set up to BBL with the same PID selection I use when logging with my laptop. I noticed that GM.BOOST is available, but GM.BOOST_DMA is not. I would just switch, but GM.BOOST_DMA is needed to "activate" CALC.ACTBOOST (Actual Boost Pressure) so I can see that one as well. Am I missing something?
    As a side note, is there a way to select CALC PIDS for BBL, or do I just need to select them once I open the log file in the scan tool?
    You can make a calc pid to calculate boost as "{SAE.MAP.kPa} - {GM.BARO.kPa}" or "{SAE.MAP.psi} - {GM.BARO.psi}" (or similar).
    Done, thanks!
    Jun 2012
    Quote Originally Posted by thunder550 View Post
    Hit the "V7" button in V8 where you configure your BBL PID list. You type in the calc pid without the "calc." prefix.
    Quote Originally Posted by ACCLR8N View Post
    Awesome, thank you!
  1. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 08:09 AM
  2. Multiple PID sets for single controller
    By Biggsy in forum Black Box Logging
    Last Post: October 20th, 2010, 11:49 AM
  3. New PID for Lingenfelter launch controller...
    Last Post: October 28th, 2008, 11:55 PM
  4. BBL PID's for Allison 5 speed
    By turbo_bu in forum FlashScan V2 BB Logging
    Last Post: August 19th, 2008, 04:32 AM
