Thread: E40 Case Issue
    Mar 2012
    Default E40 Case Issue
    I ran into an E40 LS2 with a T56, it is a swapped engine with custom harness. I can not get it to perform a CASE learn. I can see we are getting the correct brake signal, I just get a error when I hit begin. The temp is in the correct range. Is there another parameter I am missing? Does the clutch need to be depressed as well? I have been searching for a few hours now and have found nothing recent in regards to an E40.
    Dec 2007
    Needs the handbrake on as well. And that sig is via the BCM/CAN to the ECM. So.......no CASE learn.
    So, he requires a compatible BCM (with connection to hand/parking brake switch).
    Dec 2007
    Or some way of getting the right message on the CAN for the CASE learn. Maybe EFILive team could add this in to the Scantool.
    Quote Originally Posted by gmh308 View Post
    that would be a cool solution.
    Mar 2012
    Dang, I was hoping that was not the case. Thanks for the info.
    I also had a go at it with a tech2 and nada.
  1. Replies: 21
    Last Post: July 7th, 2013, 11:31 AM
  2. E40 Cam Cold Start issue........help please!!
    By quik95lt1 in forum Gen IV V8 Specific
    Last Post: December 19th, 2011, 03:31 AM
  3. Replies: 5
    Last Post: October 7th, 2011, 06:18 AM
  4. e40 experts wanted, VE issue
    By hymey in forum Gen IV V8 Specific
    Last Post: September 11th, 2009, 11:20 AM
  5. E40 Tow/Haul mode input wire at E40?
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: March 23rd, 2008, 10:55 PM
