Results 1 to 9 of 9
Thread: Any way to make E38/E67 correct injector flowrate when in boost?
    Feb 2009
    Default Any way to make E38/E67 correct injector flowrate when in boost?
    The LS9 and LSA operating systems seem to properly correct injector flowrate when they enter boost, but it seems all other E67 OS's, as well as I believe all E38 OS's stop correcting injector flowrate once they go above atmospheric pressure, and thus a fueling error gets built into the VVE and MAF tables...which can in a turbo car result in some funky fueling.
    My solution to this point has been to run a return style fuel system with a 1:1 regulator and set the injector flowrate to the same value across the board, but if it's possible, on low boost setups where expected power is comparable to the LS9 and LSA engines, I'd like to somehow tell the ECM to properly follow the injector flow rate tables into boost.
    Does anyone know the solution?
    MAP-referenced FPR is preferred...
    but, otherwise, edit the LS3/E38/E67 IFR table so that the squareroot flowrate-vs-pressure relationship extends down below 400 kPa (i.e. into the boost region).
    [ i.e. 300 kPa is 1-bar boost, 400 kPa is BARO (NA WOT), 500 kPa is absolute vacuum (un-attainable) ]
    Feb 2009
    Joe,
    Do you mean B4001? If so, this table already covers from a 128 KPA delta to a 624 KPA delta, and the information in it is correct. The problem is that the once the MAP sensor actually goes above barometric pressure, the IFR continues to actually report and be calculated as the value at barometric pressure. The data is already there, the ECM isn't following it appropriately. I was wondering if there's possibly a max MAP KPA setting somewhere that the ECM looks at, and if the MAP reads above it, it defaults to the atmospheric value instead when it looks at the IFR table.
    Hmmm, I see...
    Oct 2005
    Sounds like a question for Ross..
    2014 VF SV LS3 Maloo.
    Or not
    I got no idea about fuel systems.
    Lifetime Member izaks's Avatar
    Aug 2003
    B8034
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Feb 2009
    So if I set B8034 to the max that the MAP can actually read, then the injector flowrate will calculate properly when in boost? Awesome!!! Thank you.
    Mike, can you post your tune file so I can have a look, thanks.
  1. 07' TBSS E67 set up for boost?
    By PRAY in forum E37, E38 & E67 PFI ECM's
    Last Post: September 25th, 2012, 10:20 AM
  2. Replies: 3
    Last Post: September 20th, 2011, 01:04 PM
  3. E67 fuel fun under boost
    By scdyne in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2011, 10:08 AM
  4. Correct Fuel injector Excel calculator for EFIlive
    By 98 tigershark in forum Gen III V8 Specific
    Last Post: July 6th, 2009, 01:28 PM
  5. correct Fuel injector settings Excel calculator
    By 98 tigershark in forum Gen IV V8 Specific
    Last Post: July 5th, 2009, 07:12 PM
