Hello all,
I am new to tuning and currently working on a LS swapped foxbody with a 67mm turbo. I have combed through forums and followed many tutorials. Currently I am going through the AutoVE process to get my main VE dialed in and so far so good. Right now I am nowhere near having the boosting part of it figured out, I am running OS 3 with no MAF and a 3 bar GM map. I am confused on the Power Enrichment and the Boost VE table, should they be run in tandem or is there a way to turn the PE off.
Thank you,
Josh
