Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: how to make an LLY bench harness?
  1. #11
    EFILive Distributor Trippin's Avatar
    May 2004
    Quote Originally Posted by Biodiesel66
    88953346 connector should work for the both LB7and LLY ECM? :?
    I tried to get the part number from the dealer and had no luck. If this will work this will be great.
    The LB7 and LLY are different ECM connectors. Same TCM connectors.
    TCM Grey connector part # 15305371
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
  2. #12
    May 2004
    Trippin,
    Do you have the pinouts for the LB7 ECM?
    Not sure if this is correct pinout.
    Pin 19 = Ign
    Pin 20 = 12v
    Pin 58 = Data
    Pin 60 = Gnd
    I'll post them tonight when I get home as well.
    www.socaldiesel.com
  3. #13
    Dec 2005
    Quote Originally Posted by Trippin
    If you have the LB7 ECM connector can you post that to?
  4. #14
    May 2004
    TCM
    Grey connector
    Pin #3------------Battery
    Pin#4-------------Ign
    Pin#5-------------Ground
    Pin#30------------Serial Data
    www.socaldiesel.com
  5. #15
    Feb 2006
    and $10 for shipping....
    Does anybody know is this is the same blue connector needed for a LS1 bench harness?
    Ryan
  6. #16
    May 2004
    LB7
    I purchased a very nice premade harness. Near as I can figure these are the designations.
    Blue connector
    Pin #1 and #40------------------Ground
    Pin#20 and Pin #57---------------Batt
    Pin#19---------------------------Ign
    Pin#58---------------------------Serial
    Revised Pins 19,20 and 57 based on my GM service manual.
    www.socaldiesel.com
  7. #17
    May 2004
    Quote Originally Posted by 1998ws6
    Ryan
    LS1 uses the same connector as LB7. Part# 12191488
    www.socaldiesel.com
  8. #18
    Dec 2005
    Is that the GM part #? Just checked GM parts direct and 12191488 was no found.
  9. #19
    May 2004
    That's the number from my GM service manual.
    Looks like it's Delphi.
    www.socaldiesel.com
  10. #20
    May 2006
    Default Need Connectors?
    I'm new here but I've read that a few of you have gone to salvage yards to get conenctors, go to Delphi's distributor for connectors. Power & Signal.
    Visit: http://www.powerandsignal.com/
    Their policy is that they can mail up to 25 samples per order, that is if your a company? You can also purchase crimpers, terminals, seals.......
    Hope this helps.
    Jeff
  1. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 11:33 AM
  2. LBZ/LLY Bench Harness
    By Dream8000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2007, 03:13 AM
  3. bench harness
    Last Post: June 15th, 2006, 05:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 03:25 AM
