Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
Thread: how to make an LLY bench harness?
  1. #21
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default What Power Source?
    Well, I sucessfully built a bench harness, have a TCM connector, need to find an LLY ECM connector still, anyway, for testing, I used a Werker 7.5Ah Sealed battery, and hooked my meter in to read current. The TCM drew .365 Amps during reading and powered on. Turn the "ignition" off, and it drops to .265A, then ~30 seconds later, drops to nil (when the TCM turns off). Not a very high current. So for normal use, should I get a new 7.5Ah sealed battery and use that, or should I use the "Wall Wart" AC Adapter that delivers 12.53VDC with no load, and is rated to deliver 3A? Or should I go out to Radio Smack and get a 13.8VDC 3A Power Supply?
  2. #22
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
  3. #23
    I got myself a Speartech LS2 bench harness, with a little modification it can be used for the LS2, LLY and a few others (5cyl PCM).
  4. #24
    Jan 2006
    Quote Originally Posted by GMPX
    Neat harnesses, but WOW... not cheap. My whole deal has cost me like $20 so far, and it's really not much different than those overall. But then I like to build stuff.... Are there any other vehicles out there that use the same connector (Blue C1) as the 04/05 LLY?
    SinisterSS - Pretty cool power supply. I'll have to keep that in mind...
  5. #25
    Plenty of other vehicles use that plug from 4cyl, 5cyl, V6, but, the pinouts are different so it is necessary to install a little switch box.
  6. #26
    Jan 2006
    Pinouts are no big deal... Since I would only be using it on my LLY ECM, I would re-pin the connector. What years/models? I'm assuming circa 2004 and up?
    So far, the only ECU I've confirmed has the same connector is the 2004 3.8L Grand Prix. The ECU looks identical tot he LLY ECM from the outside... Are they the same hardware inside? Could they be programmed with an LLY OS?
  7. #27
    Jan 2006
    In case anyone's interested, per my local dealer's parts dept, the Blue C1 connector can be found on the following vehicles (but not limited to these):
    2003-2005 Cavalier
    2004-2005 Monte Carlo
    2004-2005 Grand Am
    2004 (and I'd assume 2005) Grand Prix
    2005-2007 Cobalt
    2005-2007 G7
    2005 Corvette
  8. #28
    Sep 2007
    Cougar or DURAtotheMAX or anyone else thats made a bench harness.... any pics?
    2008 Chevy DMax CCSB 4x4 LTZ LMM- EFI LIVE 500HP DD Tune, Suncoast 4 1057, 5" MBRP Turboback no cat/muff/*** , S&B Intake, SD Tie Rod Sleeves & Manifold, Cognito Pitman/Idler Arm Brace Kit, Transgo Jr., Belltech 3" Lowering Shackles, Escalade Handles, 5% tint all around, Billet Bowtie and Precision Billet Grille, V1. 10000K HIDs
  9. #29
    Dec 2005
    Quote Originally Posted by Code3Response
    Here's 1 I use on all 3 Duramax controllers.
  10. #30
    Sep 2007
    Thats real nice.... all custom made? Anyone manufacturing these things?
  1. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 11:33 AM
  2. LBZ/LLY Bench Harness
    By Dream8000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2007, 03:13 AM
  3. bench harness
    Last Post: June 15th, 2006, 05:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 03:25 AM
