Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: how to make an LLY bench harness?
  1. #31
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Here's mine as it is now. I can read/flash 97+ LS1, E40 LS2, LB7, LLY, P12, 5 speed and 6 speed Allison. I plan to add a connector for T42 and one or both of the other LS2 ECMs. Battery is a 7.2Ah sealed battery, which is in the larger box on the bottom. There is a jack on the side of the smaller box to connect a maintainer up to keep the battery fully charged.
  2. #32
    Dec 2005
    Cougar
    Where did you get the battery? I like your set-up. Small and compact.
  3. #33
    Jan 2006
    I got the battery and maintainer from Batteries Plus. It's this one.
    The nice thing is I can toss it in my bag and take it into U-Pull-It yards and check to see if a prospective ECM powers up and gives data.
  4. #34
    Oct 2007
    I dont suppose you have enough parts to make another one of those? I would buy a setup like that if you did. Let me know.
    voodoolord@msn.com
  5. #35
    That is very nice, great idea on the battery too.
  6. #36
    Mar 2007
    I guess I don't get the point of all of this. Could someone explain this to the dum..... LOL dumb. I know the what and the how, but I'm not sure of the why.
  7. #37
    Jan 2006
    I would think for R/D and selling tuned ecm's
  8. #38
    Mar 2007
    I thought we could lock the ECM.
  9. #39
    Dec 2005
    Quote Originally Posted by duramaximizer
    We can,
    The bench harness allows you to flash or read an ecm that is not in a vehicle.
    Commercial tuners like myself use the bench narness to flash the ecms's prior to shipping them.
    Tony
    www.mscservices.net
  10. #40
    Apr 2007
    What is the GM part number for the pins / terminal ends used in the LLY harness connector? Guy gave me a part number of 15356826 but my parts man can not find it. The LBZ numbers I have all reference a bin number. I was told that these were the same as what is used for the DSP 5. Thanks!
  1. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 11:33 AM
  2. LBZ/LLY Bench Harness
    By Dream8000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2007, 03:13 AM
  3. bench harness
    Last Post: June 15th, 2006, 05:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 03:25 AM
