Results 1 to 10 of 19
Thread: V2 Q about stoch setting
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    Default V2 Q about stoch setting
    on F8 what happens if you change the stoch setting on the v2 can you get it display /log a higher or lower value ??
Name:	v2 stoch.jpg
    You set it to the default value that your wideband uses.
    Aug 2008
    hi mate
    could you pleas elaborate on that for me
    what value should i be putting in ?
    tech edge 2j9
    what im trying to do is get the wideband to read 1.4 AFR richer to match the dyno readout dyno 10.1 TE wide band 11.5 ,I have re calibrated the TE in free air and also tried a new sensor
    thanks
    For example:
    say your wideband assumes stoich is 14.7 (i.e. for E00 petrol/gasoline)...
    then say you run a tank full of E10 (stoich is now 14.2), at stoich your wideband will still read 14.7;
    but if you set the default to 14.2 (either in the wideband or in V2), then V2's wideband AFR pid will now read 14.2 at stoich.
    Also note, you should be using Lambda to tune with (so you won't be dealing with differences in stoich)...
    lambda = 1.00 --> stoich/CL.
    lambda = 0.86 --> NA load.
    lambda = 0.78 --> Boost load.
    Aug 2008
    HUMMM
    what value would i have to put in do that
    thanks
    14.7 * 10.1/11.5 = 12.9
    Try setting it to 12.9.
    Aug 2008
    thanks mate
    appreciate the help
    cheers
    Aug 2008
    it does drop it but it looks like about 2.2 ish AFR but i will have to do a WOT log to to compare it to my other WOT log on full boost
    cheers
    Try (12.9+14.7)/2 = 13.8
  1. Setting up V2 for BBL...
    By joecar in forum Black Box Logging
    Last Post: May 2nd, 2011, 01:41 PM
  2. Help setting up LC1
    By Slow73 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2009, 03:51 PM
  3. Setting up A0014
    Last Post: April 7th, 2008, 02:00 PM
  4. Setting timing ?
    By Chuck L. in forum Vortec V6/V8 Specific
    Last Post: April 6th, 2008, 07:07 AM
  5. Speedometer Setting
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2006, 03:56 PM
