Results 11 to 20 of 28
Thread: Need help with LS1/4L60e tune, bad idle
    Jul 2015
    Default Need help with LS1/4L60e tune, bad idle
    Below
    Jul 2015
    OK Here we go this is all the info received from the mechanics that built the motor.
    Was a LS1 4L60e out of a 2001 Camaro @ 9.6:1 Compression
    It is now a LS1 383 with the 4L60e put into a 1967 C10 Truck
    Have original Intake and Heads, but we ported the Intake and exhaust
    Has Magic Stick 4 Cam
    Texas Speed 383 Kit
    Duration is at 50 thousands
    Intake 239 Exhaust 242
    Cam Lift
    Intake 649 Exhaust 609
    Lob is Center at 111 thousands
    All Springs and Push rods to match
    billet Comp Timing Set in at 0 Degrees
    The 4L60e has all good internals on rebuild Corvette servo and YANK converter with 3,000 stall
    I hope this helps have not done any Data Logging yet, but if you tell me how to do it I will get this done ASAP.
    Once again thanks in advance.
    Lifetime Member limited cv8r's Avatar
    May 2005
    In your log, your TPS is almost never zero or close to it at idle. So most of the time you will still be using your main spark tables,even at idle. If you look at table B5916 its value is 1.19. You need your TPS to be below this and B5917 for the PCM to use the base spark tables. You may need to do a TPS relearn or adjust your throttle for this to happen. You can raise B5916 if you cant get the TPS as low as you need. Also in your first post you say you still have the MAF, if so, why are you tuning the VE table? Not the MAF? I've attached your tune with the spark table numbers a bit closer together which may help it from hunting as much.
    Could you include GM.DYNCYLAIR in your logs, also what are your fuel trims doing?
    It's all good until it goes "Bang"
    I missed his log file, I didn't see it...
    May 2005
    First post
    Jul 2015
    Thanks Limited, I will give that a try do a data log. I just got called out of town for a few days so I should be able to get that done this weekend
    Quote Originally Posted by limited cv8r View Post
    First post
    All I see is a .ctz file...?
    Jul 2015
    Have not done any data logs if that's what you mean? I will try this weekend. Is there anything specific I should log
  9. #19
    May 2005
    AutoVE3.efi, in first post??
  10. #20
    Jul 2015
    That File is not mine, that is LS-Swappers, is that the file you went off of for the file you did re calibrations on?
  1. LS1 with a 4L60E swap with shifting problems,
    By catman3126 in forum Gen III V8 Specific
    Last Post: August 13th, 2012, 09:07 AM
  2. bad fuel economy, GEN IV swap 5.3LMG, 4L60E 2dr Tahoe
    By harascho in forum Gen IV V8 Specific
    Last Post: January 27th, 2010, 11:58 PM
  3. need a tune for 4l60e
    By blue99ta in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 5th, 2008, 02:17 PM
  4. First Tune on 4L60E
    By Gordon0652 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 12th, 2008, 11:00 PM
  5. Low (but stable) idle, bad response when cold ...
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: August 29th, 2006, 01:03 PM
