Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Need help with LS1/4L60e tune, bad idle
  1. #21
    Lifetime Member limited cv8r's Avatar
    May 2005
    Whoops, my bad. Yeah I did the wrong file.
    What are the problems you are having with your idle?
    It's all good until it goes "Bang"
  2. #22
    Jul 2015
    It will start just fine, and then when I give it gas it goes very low and drops down sometime dies, It also will die if I kick the A/C on, I do not have a wire from the A/C to the computer so I was trying to compensate the idle, if that is not a good way of doing it I can run the wire.
  3. #23
    May 2005
    Try this. I added some spark to your idle underspeed which was all zero's after about 200rpm error.
  4. #24
    Jul 2015
    Quote Originally Posted by limited cv8r View Post
    OK I loaded this file and went on a drive did a few pulls on the throttle, not sure I did a Data Log correct, but I did not see any other way to do it.
    Let me know what you think, but as of now it was much better. Thanks. I could even run the A/C and it did not fall on its face.
    Is adding some spark advancing the timing?
  5. #25
    May 2005
    It does add timing, but only to help your car from stalling, depending on the RPM error from desired idle speed. I did make a few other changes. If you do a compare between your file you uploaded and the modified one you will be able to see what was modified.
    Glad it helped you.
  6. #26
    Jul 2015
    Glad it helped you.
    Did that Log file tell you anything? I am not sure how that works, I hit play and can watch the Dashboard.
  7. #27
    May 2005
    That log file doesn't look too bad. A quick read of the scan tool PDF will help you understand viewing your logs better and how to use the different dash page.
  8. #28
    Jul 2015
    Did not know there was one, I will take a look thanks for the info
  1. LS1 with a 4L60E swap with shifting problems,
    By catman3126 in forum Gen III V8 Specific
    Last Post: August 13th, 2012, 09:07 AM
  2. bad fuel economy, GEN IV swap 5.3LMG, 4L60E 2dr Tahoe
    By harascho in forum Gen IV V8 Specific
    Last Post: January 27th, 2010, 11:58 PM
  3. need a tune for 4l60e
    By blue99ta in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 5th, 2008, 02:17 PM
  4. First Tune on 4L60E
    By Gordon0652 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 12th, 2008, 11:00 PM
  5. Low (but stable) idle, bad response when cold ...
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: August 29th, 2006, 01:03 PM
