Results 1 to 10 of 10
Thread: need some help and maybe someone to write me a new tune...
    Sep 2012
    Default need some help and maybe someone to write me a new tune...
    Okay so recently installed motorsport 100hp injectors a 10mm stroker pump and airdog 150 and cant keep egt in check love how it runs now but.hate.letting out the throttle. I have a 63mm cheetah turbo.and pushing 38# but im having to hold it back due to not having headstuds installed yet I know that turbo has allot left in it and the tune I have now at wot it's smoke till at full boost and it cleans right up maybe a slight haze that's it
    2007 cummins 3/4ton 62/74/14, afe stage 2, flopro 5", garmon tranny, isspro guages, pusher intake, grid heater delete, 35's
    Senior Member DODGE74's Avatar
    Oct 2011
    How hot are your EGT's?
    That should be a stout setup.
    06 QCLB, DRW
    Single pump
    Single turbo
    EFILive 772hp 1398tq
    gordon@innovativediesel.com
    Sep 2012
    1500 to 1600 deg if stay in it I know wont kill it if only for a few seconds but.I cant hard stay in it.for a whole.gear
    Jul 2012
    There are some pulling rigs out there making passes at 1800*. 1500-1600 is warm, but if that's where it stops climbing I'd say you are running pretty good for a race/play tune. Not sure I'd tow with it..
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Aug 2013
    I wouldnt worry about 38 psi as long as your timing isnt sky high. I run a bunch of 5.9s at 45 psi on stock head with no issues.
    The basic way to get EGT down is, more boost or less fuel. Tough to play with WOT timing without being on the dyno. Do you know how to do either?
    2004 Cummins Ram 6 speed PPE/Edge Stack MBC Decked/ported head 110# double valve springs
    1995 Mustang GTS Vert 2.02/1.60 TW heads fire ringed kenne bell 2.1L
    1993 Mustang LX Notchback DOHC 4.6 4R70W swap 2 stages N20
    Couple jeeps, civic, prelude, another mustang, couple quads, and a dirtbike
    Sep 2012
    Yes I do ive adjusted my.duration down to 2700 on main guess ill adjust my wastegate now
    Sep 2012
    Also worried with the extra stuff done to my truck I dont wanna stack any rings or.bend a rod is 27deg of timing safe or.should.back main off some more
    Aug 2013
    Quote Originally Posted by Jonesy View Post
    27 degrees main? At what load/rpm? Are you not running pilot injection? Screen shot?
    Sep 2012
    After 2800 rpm full throttle I am running a pilot but it shutsoff after 2600rpm and no post
    Oct 2011
    You're fine. I wouldn't worry about it.
    06 QCLB, DRW
    Single pump
    Single turbo
  1. BB read/write?
    By s10mods in forum FlashScan V2 BB Logging
    Last Post: April 10th, 2008, 12:57 PM
  2. Is this a good write up on how to tune
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 03:24 AM
  3. Full re-write on a LL8?
    By Alvin in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2006, 04:58 AM
