Ok, I think you have to update (there was a bug in an earlier version)...
download/install V7 and V8 from here:
Sep-2015-EFILive-Public-Pre-Release
and then update V2 firmware, do it like this:
Flash the latest bootblock/firmware into your V2:
- start V8 Scan & Tune (S&T),
- click Check Firmware,
- if the firmware needs updating you will see a button
Update Firmware, click it,
- if the V2 BBx config files need updating you will see a button to update the files, click it (see
Note below),
- click
Ok to exit the firmware update dialog box.
If you had already configured V2 BBx, then click the button you see to update the V2 BBx config.
( copied from here:
Setting-up-a-FSV2-from-scratch )
if it still does not work, let me know.
