Results 1 to 7 of 7
Thread: Calc VET Again
Hybrid View
    May 2011
    Default Calc VET Again
    Just completed modding my LS6 to pass CA smog, I added 243 heads, CAT's and the rest of the smog stuff.
    I have used a base LS6 tune and want to use CALV.VET to correct my MAF and VE table, I have gone through the CALV.VET tutorial and made the necessary changes to my current tune.
    After a run today, CALC.VET produced some numbers that created a very high area in my VE table, there are also quite a few spikes that can be due to not running the motor enough at those values.
    Does this map look OK?
    I have also posted the results on my VE table, CALC.VET produces a pretty good MAF table.
    - 2002 LS6 with 226/229 575/585 116 LSA CAM
    - 85MM MAF
    - Innovate LM1 Wideband
    - SVO 30lb Injectors (IFR Calculated)
    I have done CALC.VET before and it worked well, I am just looking figure out if I am still doing something wrong.
Name:	Screen Shot 2013-09-07 at 1.00.19 PM.png
ID:	15774Click image for larger version.
ID:	15780LS1B_0070.efiClick image for larger version.
ID:	15781LS6 VET Tune.tuncalc_pids.txt
    Try this: set VE units to g*K/kPa in the tunetool, and in the scantool change you VET map Data tab to use g*K/kPa...
    meanwhile I'll try your log to see what results I get.
    May 2011
    Yep, units are kPa in the tool and g*K/kPa in the VET map.
    I took a look at CALC VET Summary notes and viewed how to copy and paste tutorial, that tutorial uses copy and fill with labels vs copy with labels.
    I used copy and fill with labels and here is the result, it looks much better to me, does this look correct?
Name:	Copy and fill with labels.png
    Please note: we've had several emergencies with out family pets, so I'm running behind and distracted, and I do apologize.
    Ok, the problem is this:
    your VE tables shown above have % units (see upper right of tunetool VE display), but your map is displayed in g*K/kPa units
    ( are doing a paste-multiply...? )
    No, do a straight paste-with-labels (no multiplying, no filling).
    May 2011
    Ok,
    Yes, both times I used paste-multiply with labels.
    With my VE displaying % and the map showing g*K/kPa, Is this the correct sequence;
    1) copy and fill with labels
    2) paste-with-labels
    How are the VE table units changed (% to g*K/kPa)?
Name:	Screen Shot 2013-09-08 at 7.41.35 AM.png
    May 2011
    OK, I think I got it!!
    I changed the map data to calculated VE, BEN corrected [%] and now the map shows the correct units. I then copied with labels then pasted with labels to the VE table.
    Here is the result;
Name:	Screen Shot 2013-09-08 at 8.52.03 AM.png
ID:	15790   Click image for larger version.
Name:	Screen Shot 2013-09-08 at 8.51.30 AM.png
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. need calc vet help
    By whackem04 in forum Gen III V8 Specific
    Last Post: December 16th, 2012, 09:52 AM
  3. Calc vet ???
    By Chuck L. in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 02:12 PM
  4. Calc VET
    By pormgb in forum Gen III V8 Specific
    Last Post: August 28th, 2011, 10:39 AM
  5. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
