Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: unable to get to cos 5
    Jul 2011
    Default unable to get to cos 5
    i have a 12593358 os , as i understand i need to save cal. witch i have done and install 12212156 but its not in my cos bins. can i use a diff os? there is only 2 with 5 at the end, not shure what to do.
    You have to find a 12212156 file... for example the 2002 Camaro file located at www.tunefiledepot.com ----> i.e. this one: 12212156.tun
    Feb 2012
    Quote Originally Posted by cb350rx7 View Post
    Have you read the COS tutorial (you can open it from the tunetool)? It tells you which is the correct COS for you base, plus a heap of other pertinent info on the upgrade. Definitely worth reading if you haven't.
    For 12212156 you need 02020005.
    Jul 2011
    thanks joecar , darcy i have read the tutorial. was a little confused , it only shows cos and 2-3 bar tutorial. i am looking to get cos5 for nos controls, i also read on the forumn that i need to first install 12212156 to get to the cos5 is this correct or do i just follow the 2-3 bar tutorial?
    Start from either of these OS's (with the same transmission as yours):
    - 12225074 Australian Holden -> upgrades to COS5 01290005
    - 12212156 Camaro/Firebird -> upgrades to COS5 02020005
    And then COS5 is included in the Custom folder of your EFILive V7 software install.
    Yes, just follow the tutorial as if you're doing COS3.
    Here are addiional notes specific to COS5: COS5.txt
    Be sure to install the latest V7 build version from here: Update-Aug-24-2013
    Jul 2011
    ok so i have full flashed 1222156 into my ls1b next i need to cal flash, my original cal ? or just cos5 sorry newbie!
    Jul 2011
    when i try to cal flash it says cal not compatble?
    Feb 2012
    No, You can't flash the cal from your os into another os.
    Full flash the COS, then cal flash the 12212156 over it to populate all the calibration data, then follow the tutorial/notes on populating the remaining COS tables that will still be blank.
    Jul 2011
    i think something is wrong, i full flashed 122156 into my 2001 z06 and many warnings are on screen for dic. service traction oil change that kinda stuff . are we shure this operating system for the camaro will work in my z06? just want to be shure i am on the rt track here, i am try to get to cos 5
    No it wont work on a Vette with that OS as there is not a COS5 for it. You are limited to COS1, 2, or 3 with a Vette and that original OS.
    However, if you use a Vette 12212156 OS, then COS5 will work.
    (Edited after Joe's subsequent posts for clarification.)
    Last edited by ScarabEpic22; August 28th, 2013 at 07:35 PM. Reason: Updating with Joe's new info
  1. Is there any COS for e38 other than the ethanol COS ?
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: July 8th, 2012, 09:54 PM
  2. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  3. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  4. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  5. Unable to see GM PIDs
    By Babydeuce in forum General
    Last Post: May 28th, 2008, 10:04 AM
