Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 60
Thread: 4l60e
  1. #41
    Sep 2013
    do you have any pictures of what i should be looking at an what i should be trying to turn.
    last time i pulled a gearbox apart was to put reduction gears in a patrol gearbox ..... a hell of a lot different to these bloody hydraulic, electronic mondern autos.
    thanks for all your help.
  2. #42
    Feb 2013
    If you look at the pic you'll see 2 lugs on the inner part they are the drive dogs that the TC turns, try and turn the pump by them, if the pump is broken they usually won't turn, if it does turn and it all looks like it's still one pice you should be good to go.
  3. #43
    Sep 2013
    thanks heaps ij ill check it out
  4. #44
    Feb 2013
    Quote Originally Posted by lbheart View Post
    <fingers crossed> Hope it works out ok!
  5. #45
    Sep 2013
    where are you when you at home ij?
    i'm in canberra.
  6. #46
    Feb 2013
    Country Vic
  7. #47
    Sep 2013
    well i dropped the tranny and had a look.
    converter alittle burred but i think ok.
    lugs look to be broked off pump so pulled pump out and going to replace.
    with i could get one on a weekend
    now starting the car with this pump not working and selecting gears would not fuck anything else in the box would it?
  8. #48
    Sep 2013
    with i could get one on weekend
    was ment to be
    wish i could get one on weekend
  9. #49
    Sep 2013
    well took it apart and it has done damage to the housing so looks like im up for a whole new pump.....
    any idea where i can get one from?
    can i use one out of a v6 model? even replace the internals with the v8 ones?????
    anyone have one?
ID:	15879   Click image for larger version.
  10. #50
    Sep 2013
    is the pump to same in a 4l65e?
  1. im lost!!! 4l60e help
    By kistlerjm9 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 15th, 2009, 05:53 AM
  2. 4l60e question
    By chris98z71 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 20th, 2009, 11:54 AM
  3. 4l60e problems
    By chevyman98 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 20th, 2008, 03:21 AM
  4. Tuning a 4l60e
    By B A Barakus in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 26th, 2007, 02:21 PM
