Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: 4l60e
  1. #51
    Feb 2013
    Early 65 will be the same, late will have an input speed sensor but can still be used if you leave the Sensor in place.
  2. #52
    Sep 2013
    what about using one out of v6 model??????????????
  3. #53
    Feb 2013
    Quote Originally Posted by lbheart View Post
    From memory the Stator shaft is a different length, other than that they're the same but as your Stator Shaft looks damaged you'll need to replace it anyway so either new or a Donor V8 pump is needed.
  4. #54
    Sep 2013
    I dont think my stator is really damaged might have to get this 4l65e pump and chuck that in
  5. #55
    Also, besides the stator shaft being different, the V6 pump might have fewer vanes, and the rotor spring might be softer.
  6. #56
    Feb 2013
    Mine being a 2005 had the 13 Vane pump Joe, Spring I always change anyway so it doesn't drop pressure at high rpm, but good points, would be easier to use a V8 Donor as changing the Stator shaft requires a press.
  7. #57
    Sep 2013
    Thats fine I have a press and can use spring from othere pump id its 10 vane ill upgrade
  8. #58
    Sep 2013
    What torpue should I be using for the little torx bit bolt that go from stator to oump housing and that bolts that hould pump together
  9. #59
    Sep 2013
    i might not of mentoined earlier but while i have never messed about with auto internals i have done a few manuals and a fair number of engine rebuilds and a few conversion over the years and i have a full work shop short of a hoist. from plasma cutter and big welders all the way down to the smallest socket ...
    anyway ....
    i picked up a v6 auto 4l60e for $130.
    you wouldnt believe it but i had a bit of a win, it's got the orange paint and stock number marking of a reco gearbox at some point. took the pump out and pulled it apart.
    it has a 13 vane pump.
    changed everything over with the brand new stuff in my pump (except what i fucked ofcourse).
    chucked it in the press and pressed out the stator and pressed in the v8 one.
    you were correct..... it appears everything else is the same.
    all i need now is torque wrench settings for putting it all back together, do you guys have them?
  10. #60
    Feb 2013
    Cover to pump body 25NM
    Pump to case 30NM
    The Manual I have on this PC doesn't show a Tq Spec for the Stator bolts but a drop of 243 Loctite and snug them up firm should be safe enough as the bolts aren't subject to any "force" the Stator being dowelled.
    There is a special tool (A big arse hose clamp) for aligning the 2 halves of the Pump, I just use the bench top and a straight edge at a couple of places with the bolts finger tight, then "adjust" with a plastic hammer, never had a drama doing it this way.
  1. im lost!!! 4l60e help
    By kistlerjm9 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 15th, 2009, 05:53 AM
  2. 4l60e question
    By chris98z71 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 20th, 2009, 11:54 AM
  3. 4l60e problems
    By chevyman98 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 20th, 2008, 03:21 AM
  4. Tuning a 4l60e
    By B A Barakus in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 26th, 2007, 02:21 PM
