Results 1 to 10 of 20
Thread: IAT 2 Timing correction tables e67 ??????
    Jul 2012
    Default IAT 2 Timing correction tables e67 ??????
    Can we get access to the IAT 2 spark correction tables on the ZL1 e67? Or have I just been missing them?
    Lifetime Member Rhino79's Avatar
    Jul 2006
    They aren't in some os's some they are. I ran into this today on OS12653669. Major timing rape when in boost!
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
    What E67 OS has them shown? If they've been left out it's an oversight.
    Jul 2012
    The operating system that i need them for is the ZL1 12653669
    Quote Originally Posted by Y BE AVG View Post
    I'll await Rhino79's answer
    Jul 2012
    While your waiting for his answer.....
    Can we get this added, ive got four ZL1's sitting here right now that this affects. It would be much appreciated
    Jul 2006
    Ross, I pulled every Zr1, Zl1, and Ctsv file I could remember customer names on and that table is NOT in any of them, and I swear to god it used to be. There used to be IAT and IAT2. In the calibration ID section at the bottom where normally it lists calibration options, all my e67 are blank too.
    Head Calibrator
    Apr 2007
    I've never seen IAT2 spark tables in any of the E67 files I've done. Can it be added?
    Ross, here are the TBSS ones that have the IAT2 spark table. (Everyone is talking about B5147 IAT2 Spark right?)
    2007 TBSS: 12611938
    2008 TBSS: 12618164
    Missing in 2009 TBSS: 12630465
    I don't think that is for IAT sensor 2 (yes, it's badly labelled).
    I can't recall any specific table for IAT sensor #2 spark correction, I am sure they use it for intercooler pump control only.
    I think you will find in the earlier OS's before they used variable axis points it was fixed to that smaller range and they had to add the second table, in the later OS's they dropped it back to one table and expanded the range from -40 to 140 °C.
  1. Don't forget your correction tables...
    By StinkyDog in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 24th, 2012, 03:19 PM
  2. Difference between (A) and (B) timing correction tables (LBZ ONLY)
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 12th, 2010, 01:51 PM
  3. idle timing correction/TPS issues
    By hymey in forum Gen III V8 Specific
    Last Post: February 24th, 2010, 05:09 PM
  4. IAT VE Multiplier - multiplies Boost VE tables also?
    By Draco in forum Custom Operating Systems
    Last Post: June 15th, 2006, 05:02 AM
  5. Math Wizzards - BEN Factor IAT correction
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2005, 02:56 PM
