Thread: Fuel System Monitor will not Ready
    Oct 2011
    Default Fuel System Monitor will not Ready
    Like said, this car will not ready the fuel system monitor. (incomplete)
    Fuel trims are +/- 5% so that was our main worry and its not that.
    E38_0116.ctz Let me know what you find.
    Thanks.
    Last edited by joecar; October 8th, 2013 at 08:00 AM. Reason: corrected spelling in title (to allow search to work)
    Oct 2011
    Bump, need this to get a sticker.
    If you desperately need to get a sticker to keep driving it, there are ways to force the Readiness Tests to pass. I wont disclose how to do it, but if you spend some time on google it'll come up.
    What are your mods and what codes are being thrown?
    Mike, are you reading the readiness tests using V7 scantool or V2 LCD...?
    Oct 2011
    This is unlike any other emissions thing I have run into and none of the usual tricks seem to be working. No codes. Fails on any scanner.
    The list of mods is a mile long, boost, huge injectors, dual pumps.
    Its just such an unusual issue, has anyone ever had a similar issue?
    Hmmm... fuel system is a continuous monitor, it runs all the time, so it should come ready always.
    What DTC's are you seeing...?
    What DTC's have you disabled...?
  1. What does ol-failed means on the fuel system status ????
    By 400ss in forum Gen III V8 Specific
    Last Post: January 13th, 2013, 07:45 PM
  2. Evaporative purge system not ready
    By PewterC5 in forum Petrol / Gas
    Last Post: September 11th, 2012, 10:18 AM
  3. 98 to 99+ fuel system segment swap.
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: October 8th, 2008, 09:21 AM
  4. Question on Fuel System
    By Randy07GMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 17th, 2008, 06:13 PM
  5. 2 Bar tune with returnless fuel system ?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: November 8th, 2005, 04:24 AM
