Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: How to go MAFless
    May 2006
    Default How to go MAFless
    Hi
    I currently have a 2002 Z06 with LS6 engine I use solely for the racetrack. The car has custom cam with .600 max lift and a Haltech Air intake with about 460hp at the wheels.
    I am considering running MAFless since the MAF sensor recently failed and we were unable to finish a race. My mechanic believes that is unnecessary for racing purposes and we can use MAP only instead.
    Although I don't consider myself and expert tuner, I feel confident modifying the tune as I have modified the Timing tables the PE and some of the idle tables as well as other tables over time.
    I've read some threads that address this issue and I am willing to give it a try but have the following questions:
    1. Do I need to convert to a custom operating system or Is it a setting I can just set to ignore the MAF sensor using my actual OS?
    2.If I go MAFless will this affect my actual timing and fuel mixture?
    3. Once done, what behavior should I expect from the car that would be considered normal? Idle issues etc.
    4. Can someone please provide a step by step of the process?
    I really appreciate any help with this issue.
    best regards,
    NoEsFacil
    If you get a MAF DTC, then the PCM ignores MAF and runs from VE... BUT you must make certain that the MAF DTC triggers immediately (you may have to edit tables C6001 and C2901).
    If VE is correct then you will see no change (ignition timing is computed from cylinder airmass, which is computed from VE or MAF, whichever one is being used).
    If VE matches MAF (i.e. is correct) then you won't notice any other behavior.
    Read calibration from PCM and save to file.
    Locate table C6001: set P0101, P0102, P0102 to A:1-Trip.
    Locate tables C2901 and C2903: set both to 1.
    Save to file, then do cal-only flash.
    As usual with Corvette, before flashing, make sure other modules are not attempting to talk on the bus.
    When PCM ignores MAF and failsover to VE, one of the MAF DTC's should be present (and MIL illuminates).
    Feb 2013
    What are tables C2091 and C2903: set both to 1 Joe?
    My OS doesn't have these.
    Try C2901 and C2903. They are in the Engine Diagnostics/MAF/Parameters
    If you don't see them, post your file. There may be something compatible.
    Al
    Feb 2013
    Nope don't have either of those
    thanks Al!
    Attachment 15815
    Ok, looks like you have a 2006 not a 2002. Big differences but it appears as if you have the MAF fail mods done. The enclosed photo is from a 2002 OS.
    Al
    Lifetime Member limited cv8r's Avatar
    May 2005
    A read through these may help you out as well.
    It's all good until it goes "Bang"
    Feb 2013
    Quote Originally Posted by ChipsByAl View Post
    Al
    Thanks!
    Aug 2010
    At a glance, that tune is from an early E38 and is configured for a 6.5L engine, large injectors, and a 2.5 Bar MAP ... fairly far from an LS6.
    Feb 2013
    Quote Originally Posted by Taz View Post
    Correct Taz, was just curious about the C2091 and C2903 Joe mentioned as I'd never seen them before
    (still have my L plates on for all this)
  1. MAFless??????
    By Rvettej in forum Gen IV V8 Specific
    Last Post: June 25th, 2021, 12:20 AM
  2. mafless tune help
    By vcls1 in forum Tutorials
    Last Post: March 15th, 2012, 05:52 PM
  3. mafless patch
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: November 19th, 2010, 08:01 PM
  4. Going MAFLESS and O2 less
    Last Post: February 12th, 2008, 09:08 AM
  5. mafless/pcm
    By zrx1200 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2005, 01:48 PM
