Results 1 to 9 of 9
Thread: Benefit to STABLE lower idle rpms? And question on truck intake marine IFR
    Jan 2013
    Question Benefit to STABLE lower idle rpms? And question on truck intake marine IFR
    1. Currently I have my GMC Sierra 1500 rcsb cammed lq9 idling stable at 725 rpms once up to operating temp.
    I was wondering if there are any benefits to have a STABLE, lower idle rpm than that. Something like 600-650rpms.
    Would there be any noticeable mpg increase, or anything else worth note?
    2. My injectors are supposed to be 8.1 marine injectors, am I right by having my flat vacuum referenced IFR table at 43.8?
    1. 725 rpm is fine.
    2. what is their flow rating...? Yes flat.
    Jan 2013
    1. 72 rpm is fine.
    1. So no real benefit to lower rpms at idle then?
    2. I bought them used so not totally sure. Think they are supposed to be between 42-44.
    Have it set to 43.8 and at WOT the afr was ~14.1
    I have stoich set at 14.026 for e10 and PE Fueling at 1.16 of eq
    Are they rated to flow 43 lb/hr at 3-bar or 4-bar...?
    Your rail pressure is 4-bar (58 psi)...?
    Jan 2013
    Ill have to look for the part number and look up the information.
    Measure your rail pressure (with manifold reference disconnected).
    Dec 2006
    The marine injectors are rated at 43.8lb/hr at 4 bar. As I recall, those numbers are using regular unleaded gas, not E10.
    Jan 2013
    Quote Originally Posted by Gordy M View Post
    Ok that sounds good.
    After correcting for my first calc.vet, today the afr is much more in line with accurate. So we'll see how the next wot run is.
    Ok, rated at 43.8 lb/hr @ 4 bar: so you're good to go, IFR table is flat 43.8 lb/hr all across.
    Also note: make sure your rail pressure measures 58 psi (4 bar) with FPR reference hose disconnected during measurement.
  1. Can you tune for Higher Torque a lower RPMs?
    By Laychut in forum Gen III V8 Specific
    Last Post: April 24th, 2012, 07:39 PM
  2. Mercruiser Marine intake injectors
    By onegonewild in forum Vortec V6/V8 Specific
    Last Post: July 22nd, 2008, 11:21 PM
  3. 0411, marine intake and 4L80E
    By hquick in forum Custom Operating Systems
    Last Post: November 24th, 2007, 02:43 PM
  4. Marine Manifold and idle tune...
    Last Post: October 20th, 2007, 11:15 PM
  5. Low (but stable) idle, bad response when cold ...
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: August 29th, 2006, 01:03 PM
