Adjusting Pilot Timing when Base Timing is changed?
I would like to know how important it is to scale back pilot timing as you increase base timing. One of the first thing I experimented with on my tunes was to use a timing calculator to set my timing tables with a minimum of 50% injection event BTDC while retaining any stock value that was above 50% BTDC. After reading about piston crack and large PW’s causing fuel to be injected above the piston bowl I realized that when base timing is increased so is pilot injection timing. So here’s where my thought go crazy. I was think that I could recalculate the Pilot 1 Timing Base (B1201) and reduce the amount of microseconds before the main injection event so that even with a modified Main Timing (B0909) I could time the Pilot injection event so that it would take place at the same time as a stock tune. Would this work? Would PW of Pilot overlap the Main injections?
I did a little bit of work calculating this but I am not sure if this is worth pursuing.
So far I made an excel spread sheet that converts main timing base from degrees to microseconds. Here's what I have for notes:
Pilot Injection Timing/PW Calculations
(Alt 0181 µ)
Convert rpm to deg/µs (*/µs)
((rpm/60seconds)/1000000microseconds)x360*= degrees per µs. Simplify equation: (3608/100000µs=0.00036) 60/0.00036=166666.666
Therefore rpm divided by 166666.666 = */µs (degrees per microsecond)
Example:
-0.5* of timing from the table divided by */µs at say 800rpm (800rpm = 0.0048*/µs)
(do not divide by -0.5. divide by 0.5 and then convert it to negative).
0.5 / 0.0048= -104.166µs ATDC
Now look at Pilot 1 timing base. At the same rpm/mm3 it calls for pilot injection to start 900µs BMI before main injection.
So, if main timing it happening at -104.166µs BTDC (in this case ATDC) add 900µs to that to find out when the pilot injection event starts. In this case 795.834µs BTDC.
Take the above µs BTDC and multiply that by */µs for the given rpm and you will get the pilot injection timing in degrees
795.834 x 0.0048= 3.82* BTDC
So what im thinking is that I can calculate the stock timing in *BTDC of the pilot injection event and keep it constant while adjusting base timing. Im sure this could affect some other things so I would appreciate any input.
