Results 11 to 20 of 22
Thread: help with calc_pids.txt file
  1. #11
    Aug 2013
  2. #12
    Aug 2013
    Attachment 15868
ID:	15875   Click image for larger version.
ID:	15876   Click image for larger version.
  3. #13
    Aug 2013
  4. #14
    Aug 2013
    Yes, and No.
    If I need to also select and log BARO, then that may be my problem. I just assumed it would know what BARO is and subtract it, but obviously it can't know exactly what BARO is at any given moment unless I'm monitoring (logging) it.
  5. #15
    Aug 2013
    Did you copy the new cal_pids.txt file to the User Configuration folder...?
    In the V7 scantool, on the PIDs tab, did you select these pids: CALC.BOOST, SAE.MAP, SAE.BARO...?
    That last post was for this ^
  6. #16
    Aug 2013
    Wait, I'm confused. The PIDS I selected for Datalogging were in V8 in BBX, I don't recall selecting any PIDS in V7 at all.
  7. #17
    Aug 2013
  8. #18
    V2 BBL cannot log a calc pid on the fly.
  9. #19
    Are you logging with V7 and a laptop in vehicle, or with V2 in standalone (no laptop)...?
  10. #20
    If you log with V2 BBL:
    - configure BBL to log SAE.MAP and SAE.BARO,
    - program into V2,
    - take V2 to vehicle and log,
    - take V2 to laptop
    - uplod log to PC,
    - continue on as in next paragraph:
    If you log with V7 scantool/laptop:
    - run V7 scantool,
    - goto PID tab,
    - click on the heading of the last column on the right (to sort by this column),
    - locate and select the pid CALC.BOOST,
    - save log file (to save the calc pid into the log file),
    - goto Dash tab,
    - on gauge/chart select the pid CALC.BOOST (in psi),
    - you should be able to view the CALC.BOOST data.
  1. CALC.VET calc_pids.txt for serial LC-1?
    By Rich Z in forum Gen III V8 Specific
    Last Post: January 21st, 2013, 09:02 AM
  2. Replies: 13
    Last Post: June 4th, 2011, 02:34 PM
  3. Help with calc_pids.txt file...willing to paypal money
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: October 5th, 2010, 02:59 PM
  4. Install help please...vista...run as administrator..cant open calc_pids.txt
    By skippy in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2009, 10:12 AM
  5. calc_pids.txt?????
    By the4wheeler in forum General
    Last Post: October 23rd, 2008, 04:23 PM
