I'm kind of confused after talking too a gentleman online. We are talking OBD1 LT5 DOHC 350's. He has gotten me all confused about a simple, simple topic. To clear my mind.
I have a PFI injector that flows 21 lb/hr @ 39psi
The LT5 has a KOEO(key on engine off) rail pressure of 55 psi.
Idle pressure is 43.5 psi
When calculating for the IFR to be entered into the calibration
Using an IFR calc: I use the 39psi as the old pressure
And 55 psi as the new pressure
And 21 lb/hr as the rating of the fuel injector
I punch these into this calc and get 24.94 lb/hr@55 psi. Isnt this the number that is entered into the calibration for IFR?
He is say ing that you use
And 43.5 as the new pressure(he says you use this vaccuum referenced pressure as the nominal pressure)
21 lb/hr as the rating of the injector
He gets gets approx 22 lb/hr.
here is the calc I used.
So when doing injector IFR calcs, do you use regulated pressure or unregulated pressure numbers in teh calculator.
thanks in advance
peace
Hog
