Results 1 to 2 of 2
Thread: parking lot idle
    Jul 2008
    Default parking lot idle
    I'm trying to straiten out some idle issue when im in a parking lot coming down from a roll... its not very consistent as to duplicating it. just seems it has to be warm for it to happen.
    at times when pulling into a parking lot or maneuvers in the driveway the car will stall or almost stall its very random..
    what I'm wondering is if I should
    add more air in B4309 in the 1000 rom row?
    drop b4312 from 2 KMH to 1 KMH ? (I dont want a hanging idle but a slight 1/2 - 1 second delay would be perfect)
    Since this is a tuning site.... LS1 swap, 224/228 .588/.588 114+1 , LS6 intake , Ported TB, LS6 Valley cover (huge difference in oil usage!) 36# grand prix injectors, SLP Thirdgen dual air box cold air, Stage 2.5 Ported PRC ls6 heads, Hawks ls1 1 5/8 swap long tubes, SLP Thirdgen Catback t56, spec 3 clutch, S60 street 3.73 rear. LC-1 WB , Roadrunner
    Jul 2012
    There was another thread with a similar case. I can't remember the thread title at this moment, but the cause was stall saver timing fighting airflow.
    Let me see if I can find it
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
  1. Did the auto VE now runs a lot better in SD than with MAF
    By isak81 in forum Gen III V8 Specific
    Last Post: February 20th, 2012, 03:09 PM
  2. A lot of PID's missing
    By joshp14 in forum FlashScan V2
    Last Post: August 1st, 2011, 12:15 AM
  3. Service brake system w/ABS light and Parking Light on
    By mshirshe in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 13th, 2010, 03:32 AM
  4. can you make a 98 5.7 vortec run a lot better????
    By tfkostecki in forum Vortec V6/V8 Specific
    Last Post: February 26th, 2009, 04:28 PM
  5. Wow, i've got a lot of tuning to do!!!!
    By Loudmouth LS1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 16th, 2007, 12:15 PM
