Results 1 to 7 of 7
Thread: Lm-2 to v2 cable
    Jan 2012
    Default Lm-2 to v2 cable
    hey guys need a cable to connect my new Lm-2 to my v2 taq website is down has been for ages any ideas on where to get them from or do i have to make one?
    cheers james.
    You will have to make a cable.
    Flashscan-to-LM-2-Serial-Cable
    Jun 2007
    Surely we have a forum member that knows where the stuff can be sourced to make a cable. The cable I have only uses 3 of four poles coming from the serial output to the EFILive RS232 plug.
    Isn't there a better alternative to buying the Innovate serial programming cable (#3840) and putting the RJ11 connector on it? The lowest price I've seen on the Innovate cable is about $20 delivered & a pack of RJ11 ends is about $6 plus tax from the big box home improvement stores.
    I have to believe there is a better less costly way to make the cable. Somebody probably sells that molex plug & a piece of cable for around $5, but who?
    Does Google or Ebay produce any results...?
    Jun 2007
    You need to know more than I know to do a proper search. I tried to identify the molex plug that connects to the LC-1, LM-2, but I could not find it after searching for it for quite a while. I imagine if I knew a number or other identifier for the molex plug I might be able to come up with something.
    Jun 2007
    OK. It's a Molex micro-fit receptacle that's required. #43025-0400
    Ok, other than Molex, I would not have known that is the name of it (I don't have a LM-2).
    I see they're cheap, what is the minimum quantity they make you buy...?
  1. V2 cable
    By Chevy366 in forum FlashScan V2
    Last Post: July 24th, 2012, 08:26 AM
  2. Cable licenses
    By duke1098r in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 28th, 2011, 01:40 PM
  3. why do I have a com cable and what to do now?
    By C5Vette in forum FlashScan V2
    Last Post: July 4th, 2008, 11:14 AM
  4. Cable
    By Stingray in forum General
    Last Post: August 20th, 2005, 01:04 PM
